Earlier on my pc i was useing DVI-D cable for my monitor (T2200HD Benq) running at 1920x1080p then everything was fine , but recently when i needed DVI-D cable for Playstation 3 i have to choose VGA .
i started noticing that the screen is flickring like CRT monitors . the refresh rate shows 60Hz at 1920x1080 .
I use nVIDIA 8400GS non overclocked
are there any problem ?
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
^^ It should. Playing high def is another story.
@ max demon: Based on what you said, issue is on the VGA. Try to borrow a vga card and see if you are getting the same issue from there. If you are not, the flickering vga needs to be fixed.
