Old 21-03-2009, 11:19 AM   #1 (permalink)
awesomeabid's Avatar
Default Wat's beter..?? AMD Athlon 64 X2 6000+ or 6400+
heyy guys..!!
can u plz lemme know which one of the processors is better
Processor- AMD Athlon™ X2 Dual-Core
Model 6000+
OPN PIB ADX6000CZBOX
Operating Mode 32 Bit Yes
Operating Mode 64 Bit Yes
Revision F3
Core Speed (MHz) 3000
Voltages 1.35-1.40V
Max Temps (C) 55-63
Wattage 125 W
L1 Cache Size (KB) 128
L1 Cache Count 2
L2 Cache Size (KB) 1024
L2 Cache Count 2
L3 Cache Size (KB) 0
CMOS 90nm SOI
Socket AM2
AMD Business Class No
OR
Processor AMD Athlon™ X2 Dual-Core
Model 6400+
OPN PIB ADX6400CZWOF
Revision F3
Core Speed (MHz) 3200
Voltages 1.35-1.40V
Max Temps (C) 55-63
Wattage 125 W
L1 Cache Count 2
L2 Cache Count 2
CMOS 90nm SOI
Socket AM2
also mention a suitable mobo within 6K...!!??
please post your views as soon as posible....cant wait to buy...m sick of old PC..!!
and what does OPN Tray mean ???
awesomeabid is offline
Old 21-03-2009, 11:38 AM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: Wat's beter..?? AMD Athlon 64 X2 6000+ or 6400+
both r not worth , gor for AMD X2 7750 for 3500/-
damngoodman999 is offline
Old 23-03-2009, 11:15 AM   #3 (permalink)
yeah...i've finalised my plan .....
i m goin for AMD X2 7750 BE ...wid Biostar TA790GX 128M mobo......
and i've opted for corsair 2x2 GB DDR2-800 along wid corsair cx-400 PSU
is there any problem with the PSU stuff.... i've heard that this model of corsair is efficient more than 80%.....and it also goes with my budget....!!
Old 23-03-2009, 02:16 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ nice choice mate. go for it
desiibond is offline
Old 24-03-2009, 01:45 AM   #5 (permalink)
dOm1naTOr's Avatar
yup, 7750 has gud vfm.
though its 2.7Ghz, the l3 cache gives it an edge over 6000/6400+. Still 6400+ beats it in most benchs but 6400+ is way expensive.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
