Old 20-03-2009, 09:57 PM   #1 (permalink)
Thumbs up Suggest a best DVD writer!! Urgent
Hello friends,
Please suggest a Dual layer DVD Writer (IDE) which is best one with the model number and price.
Budget 1k-2k
Any Blue ray or HD-DVD writer is available.Please suggest.
I've already a DVD writer of the Sony AW-G170A which is not ready self writed DVD and other system writed DVD. At this time it not writed the DVD's & CD's.If any solution provide me i really thank to u.
goel.suraj is offline
Old 20-03-2009, 10:20 PM   #2 (permalink)
j1n M@tt's Avatar
Default Re: Suggest a best DVD writer!! Urgent
Sumsung DVD writers r the best now in market...but I think they hav only SATA models now, dunno abt IDE models
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 21-03-2009, 03:55 AM   #3 (permalink)
Point Blanc
there are both sata and IDE burner available in the market from samsung, same for sony and asus.
sata burners are better as compared to IDE burners.
IMO Samsung Sony Asus LG all are good, you need to see which ones run longer.
I had a sony burner, worked very good for me, used it as internal/external burner as I did not had my own PC earlier. and it got kept for 4-5 months without use after which I found it not working, did not got it repaired had bought it in 2.6K and by the time I was looking again price had become very low and then I bought an asus burner in 1.2K that was around 6 months back
Posted again:
for your burner, it may need firmware upgrade and then start working again, otherwise the lens inside has gone bad and you can get it repaired or your burner RMAed if under warranty.
acewin is offline
