Old 19-03-2009, 03:39 PM   #1 (permalink)
Unhappy Intel DG33FB Automatically rebooting every hour
hi
I got a strange problem with my intel DG33FB Motherboard.
The PC is working fine when suddenly; one of the PC fans inside the case audibly increases fan speed and a 4-5 seconds later the system resets. Once the system is back online the same thing is likely to occur EXACTLY one hour later.
PC Specs: Intel Dual Core E2140,Intel DG33FB Motherboard, 1 GB X 1 Transcend DDR2 667Mhz, Seagate SATA 160GB, Circle Cabinet with 400w PSU
EDIT:When the system reboots, nothing is even slightly hot. I have run the intel system monitoring software and all temperatures are in the green before the system resets.
SystemError is offline
Old 19-03-2009, 03:48 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: Automatically rebooting every hour
It is a problem with the Intel motherboards. I mean me too having a P5PE-VM Intel Original Motherboard had the problem but I get rid from it.
If you have same BIOS options like me try to do this,
Go to the BIOS
Go to the Advanced tab
Click Hardware monitor
Enable the Fan Control
It will reduce the noise significantly.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 19-03-2009, 04:01 PM   #3 (permalink)
The noise comes only a few seconds before restarting.. after the restart the fan runs normal.
Old 20-03-2009, 09:07 AM   #4 (permalink)
Call me D_J!
^^ Did you do what I have told?
Old 20-03-2009, 09:36 AM   #5 (permalink)
Intel BIOS does'nt have those options.. there is only Processor Zone Respose(set to AGGRESSIVE/NORMAL/SLOW) and Processor Zone Damping(HIGH/NORMAL) so its set to NORMAL i n both i guess that is Automatic Mode.. but even changing those does'nt help me with the restarting problem.
Old 20-03-2009, 11:05 AM   #6 (permalink)
Could be due to overheating .Try running your PC with cabinet open and .
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 20-03-2009, 01:24 PM   #7 (permalink)
@backlight.. yup tried that too.. and also changed the PSU
Old 20-03-2009, 03:58 PM   #8 (permalink)
can u provide some more info about this issue like since when is it happening ,is it a new PC , did u do any upgrade recently anything which could help in pinpointing the issue ?
Old 20-03-2009, 04:20 PM   #9 (permalink)
Call me D_J!
It may also be due to overclocking. Did you overclock your CPU or has the service man overclocked it?
