Old 19-03-2009, 12:53 PM   #1 (permalink)
1Click to Rule them All
strider21's Avatar
Question PC Hardware affected with an UPS with no backup
My PC is connected to an UPS (which is connected to a Spike buster). The UPS battery has died out and my PC turns off immediately on power cut.
Does the Processor,Mobo,PSU,HD or any other component gets affected without a proper shutdown?
One click to Rule them all |Wickedwonder|
strider21 is offline
Old 19-03-2009, 01:54 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: PC Hardware affected with an UPS with no backup
Now i have the same problem though my UPS gives back up to 4 secs in which I can off the monitor and press the power button to shut it down. Many times my computer hanged when I was not able to shut it down within 4 seconds but it hasn't done any damage yet. But my PSU has become weak as it sometimes takes more than 1 min. to start the comp.
I think that your MainBoard does get affected on direct shutdown. If you have to shutdown the PC frequently due to power failure, better take a UPS.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 20-03-2009, 04:06 PM   #3 (permalink)
i can think of a few dangers you may face
1) Hard disk corruption - If PC turns off immediately,your HDD write heads wont align and could cause damage to hard disk - causes bad sectors and data corruption
2) Power surge - Not sure if your spike buster is capable of handling power surges - can fry up your RAM or worst case affect your mobo
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 21-03-2009, 03:37 AM   #4 (permalink)
Point Blanc
atleast get a UPS which can do auto shutdown due to power failfure.
I got an intex UPS of 600VA, just lets me shutdown my system in 2-4minute of time,nothing more than that.
acewin is offline
