my pc is a branded one..............
the problem is that it sometimes gets off suddenly and when i try to switch it back on nothing happens.......
after i switch the ups off and then switch on the ups,....the pc starts normally..and again gets off most probably within 5 minutes.......
but if i leave the system and ups off for a while and try to on the pc again...........it works fine for a longer while and some times gets off after some hours.............
its a branded hcl pc..........HCL ezeeBee
my pc configuration is
gigabyte 81845GVM-RZ Motherboard
processor Intel P4 2.26 GHz
seagate st340015A 40 gb ATA IDE 5400 rpm HDD
256 MB DDR RAM
i tried updating the bios.........
reflashed it to older version as i didn't get the hcl version of the bios
changed the CMOS battery.............
nothing works............
recently i discovered the power supply is a 300w HCL...........
but it had worked fine for about 4 years ..so there should not be any shortage of power.......
please please please i am not able to uderstand the problem
hope all details r given.help me solve this thing.
