Originally Posted by rhitwick
Hi, how old is ur system?
AMD+512RAM+40GBHDD, seems pretty old (at least 2-3yrs).
U should check the PSU first
Then RAM and then MOBO battery.
Report back!
Ya.. my system is almost 6 n a half yrs old..
is it a thermal shutdown??
Posted again:
Originally Posted by chandal_keta
this might be due to ur power supply to bro..i think ur internal fan might be jammed!!clean it thoroughly...and even if doesnt run fine..i think u better change ur power supply once and try it!!!good luck!!chandal
Na bro.. power supply is just working fine.. double checked.. bt neway.. thanx..
Posted again:
Originally Posted by damngoodman999
+1
check the Cmos battery
And also RAM ,, did u install latest application ??? like anything ??
CMOS battery had been changed a month back.. bt yeah.. i installed GTA SAN Andreas game.. and played it for a couple of weeks.. this problem started just after that..
