Old 16-03-2009, 07:32 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default Prob with WiFi settings!!
I have a Dlink wireless router connected to Beetel modem (Airtel).. The WiFi is protected with WEP standard.. the prob is that when I try to access the Wifi frm my PDA (O2 orbit) or HTC touch, the connection establishes but the data flow is only for few seconds.. Like if I'm openin a site, then I have to refresh the connection on my PDA for openin each new page.. Wifi works fine on my laptops though... what cud be the prob??
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 16-03-2009, 10:32 PM   #2 (permalink)
D PrankMaster
prankie's Avatar
Default Re: Prob with WiFi settings!!
anyone???
prankie is offline
Old 17-03-2009, 01:26 AM   #3 (permalink)
The Sorcerer's Avatar
Change the channel on your wireless router to either 1,6, 9 or 11. See if that works.
The Sorcerer is online now
Old 20-03-2009, 04:15 PM   #4 (permalink)
D PrankMaster
prankie's Avatar
Tried changing the channel... but the prob remains..
prankie is offline
Old 21-03-2009, 01:17 AM   #5 (permalink)
Did you try to connect your htc on someone else's wifi connection?
Old 21-03-2009, 01:37 AM   #6 (permalink)
Its against the law to run a wireless connection without any encryption so do not under any circumstances consider this as a permanent fix. If it works, re-enable the encryption again and see if your pda has any updates. If not then contact your dealer/service to get it checked.
Old 21-03-2009, 02:05 AM   #7 (permalink)
It was all over the newspapers and news channels. Its pretty effective since Khalsa college, Mumbai also had bit of an issue in this:
http://news.webindia123.com/news/art...7/1072991.html
In any case why would someone let an internet connection be used as a public property when its being paid by an individual and he/she got wifi for personal use?
