Old 16-03-2009, 11:36 AM   #1 (permalink)
Question machine slowing down!!
config:
C2D E4500
XFX 8600GT 512MB
ASUS P5DL2 VM SE
2x1 GB Zion 800Mhz
when i first got my hands on COD4:MW I ran it on the above config at 1024x768 with everything on and max. no hitches whatever. now i have to run it at 800x600 and some fx turned off to run it smoothly.
it may be a virus. but i dont have internet connection at home and the trial avast AV software i have, i suspect, is not enough. getting updates is a prob, even from digit dvds.
any suggestions?
Stormridah is offline
Old 18-03-2009, 10:28 AM   #2 (permalink)
Default Re: machine slowing down!!
Hello? ne1 out there?
Old 18-03-2009, 10:33 AM   #3 (permalink)
damnbadman666
damngoodman999's Avatar
ya , avast 4.8 is not trail its full version u can get KEY from registering on the INTERNEt
U r problem doesn't seems to virus ???
Can refer the error the message ???
damngoodman999 is offline
