Old 15-03-2009, 10:15 AM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Exclamation 5800 XM woes
hello guys this is my first time xperience from nokia . i have recently got nokia 5800 i was earlier iphone and sony ericsson user , they rarely give me problems .
but this set wants me to install nokia PC suit which is the worst software i feel , but looking at the features i thought ok . the phone has many bugs and glitches, i thought that i must upgrade its firmware , i installed NokiaSoftwareUpdaterSetup_en_us.exe and started as normal . after a heavy download it started to update . but the progress bar was not going above 10% after 15 mins i got frustated and removed the cable and started the phone . it worked normal , then i replaced the battery and started the update again ( this time i have choosen mass storage) again same problem . so i decided to put some music and videos ( not all wer p0rn)
but i later found out that the mass storage is disconnecting and reconnects randomely .i couldnt transfer the files ..
also this phone hangs oftenly esp. during installing apps
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 15-03-2009, 08:11 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: 5800 XM woes
^I have none of the mentioned problems you have...
My site: collegeclassroom.org
amitash is offline
Old 16-03-2009, 01:01 AM   #3 (permalink)
Point Blanc
you need to follow up in this thread, I hope it helps you with other 5800 users to guide Thread Name -- Official Nokia 5800 XpressMusic discussion thread
acewin is offline
Old 16-03-2009, 02:52 PM   #4 (permalink)
S60 rocks
rajhot's Avatar
1) Perform a hard reset on ur phone using *#7370# .
2) Take ur mobile to ur nearest nokia care centre for upgrading the software unless u have a 2Mbps broadband connection. You should not remove the cable during an upgrade.
Proud Owner of N82! :cool:
rajhot is offline
Old 16-03-2009, 03:20 PM   #5 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i formettend the memory card and the memory card removable disk problem was solved .
i will take the nokia phone to nearest service center soon
Posted again:
