Old 13-03-2009, 07:53 PM   #1 (permalink)
GeekyBoy's Avatar
Default Upgrading my pc
My current PC configuration can be seen below in my signature.
I have a budget of Rs 9000. I want to upgrade my system, so that it can easily play HD content, and it must have a very good onboard graphics subsystem, so that I can play most of the games without stuttering.
The components I want to upgrade are motherboard, processor and RAM.
Can anyone please suggest the best at this price? [Also mention the price of each component]
My current choices:
1. Processor-AMD athlon x2 7750 BE or Intel Pentium Dual Core E5200
2.Motherboard-Dont Know
3.RAM- 2gb DDR2 800MHz Transcend RAM.
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 13-03-2009, 08:21 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Upgrading my pc
Athlon X2 7750 B.E. - - Rs. 3,500
Transcend 2*2=4GB DDR2 800MHz RAM - - Rs. 2,250
Biostar 780G + SB 700 - - - Rs. 3,200
Onboard graphics:-
HD3200(HD3450 without memory)
40 Stream Processors
DX10.1 support
Run any old game(a.k.a. older than 2008) with good quality settings, and HD content is a piece of cake.
http://pleaseguide.me/
comp@ddict is online now
Old 13-03-2009, 08:29 PM   #3 (permalink)
GeekyBoy's Avatar
Onboard graphics:-
DX10.1 support
Thanks but how about Gigabyte MA78GM-S2H in place of the Biostar 780G + SB 700 ? Which one is better?
Is there any intel alternative I can get within this price?
GeekyBoy is offline
Old 13-03-2009, 08:50 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well, do you need HDMI? If not, just stick to the Biostar, as it's not worth spending an extra 1k when both will give same performance.
Old 14-03-2009, 06:54 AM   #5 (permalink)
toofan's Avatar
You can go for E7300 and use some cheaper motherboard with that. It won't be costlier then 3 thousand and then buy Kingston 2gb 800 Mhz for Rs 1200.00
Posted again:
Comp addict can mention some cheap mobo for you in that budget.
E7300 5500
RAm: 1200
total: 6700
9000-6700= 2300 add an extra 1 thousand and go for that Mobo which compadict mentioned.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 14-03-2009, 02:15 PM   #6 (permalink)
GeekyBoy's Avatar
Has the biostar mobo got DVI output ?
Another query: Will an ordinary 400w smps be ok for this system ?
GeekyBoy is offline
Old 14-03-2009, 03:20 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get CM 460W for Rs. 2,400
or
Powersafe Silver 400W for Rs. 1,200
Old 14-03-2009, 08:58 PM   #8 (permalink)
GeekyBoy's Avatar
or
What kind of graphics cards will be safe to use with the the powersafe silver ?
Can I install a 9600gt without probs.
I have an Intex 400w smps right now. Will it support the config you and the others specified?{due to cash constraints, not thinking of buying the powersafe right now}
GeekyBoy is offline
Old 14-03-2009, 11:57 PM   #9 (permalink)
Rig It Up
I suggest you better go for CM 460W. It is enough for 9600gt.
Crossfire is offline
Old 15-03-2009, 11:02 AM   #10 (permalink)
toofan's Avatar
go for any thing form good brands 500w(if you will upgrade in future).
Other wise 450w is more then enough for 9600gt
Check my work at:
toofan is offline
Old 15-03-2009, 12:23 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
9600GT shud work, but I strongly recommend a CM 460W, or maybe a POV/Zebronics 500W whichever is at lower price tag.
Old 15-03-2009, 02:53 PM   #12 (permalink)
GeekyBoy's Avatar
I dont want to spend much on the SMPS. As I have already mentioned, my budget is limited to only Rs 9000. So, I think i'll be buying the powersafe one.
Anither query: In one of my earlier threads, I had enquired about a 19" LCD within Rs 8000, from which I got no replies. Could anyone be please suggest me one?
Thanks and keep the valuable suggestions coming in.
GeekyBoy is offline
Old 16-03-2009, 12:33 AM   #13 (permalink)
Point Blanc
well why 19 inch, when the the best monitor in your budget is Benq T2200HD which is a full HD monitor
go with amd config, many reasons
Posted again:
well why 19 inch, when the the best monitor in your budget is Benq T2200HD which is a full HD monitor, it may cost you around 9-9.5K
If it is out of reach due to budget issues, then Dell 1909 is what you are looking for cost is 7-7.5K, check with Dell, and availability with local dealers.
go with amd config, many reasons, nothing can beat it in the given budget
POV is better than Zebronics
acewin is offline
Old 16-03-2009, 01:58 AM   #14 (permalink)
GeekyBoy's Avatar
Is dell 1909w the best or are there better alternatives from other companies(like viewsonic or samsung )?
Wait a sec guys.....hows the 9300 chipset? I've heard that its IGP's the best?
Do you know of any good nvidia 9300 based mobo within Rs 4000?{I think its on the intel platform}
GeekyBoy is offline
Old 16-03-2009, 03:03 AM   #15 (permalink)
The Sorcerer's Avatar
Wouldn't count on viewsonic- their really bad customer support and warranty honour is an epic fail. Dont know much about samsung screens.
Its on intel platform- but not the best. Onboard graphics is better off with AMD honestly. 790gx gives a better kick against the 9300 chipset. Besides nvidia still havent perfected the CAS 4 latency on their chipset yet. Nvidia once admitted themselves that they havent implemented the advance path feature to get proper support for memory timings to work properly.
Out of curiosity- which power supply?
The Sorcerer is offline
Old 16-03-2009, 03:33 AM   #16 (permalink)
GeekyBoy's Avatar
Well, I've read reviews, which favour the 9300 in the graphics department, way ahead of 780G. Could I please know the names of a few motherboards and their respective prices for the 9300 chipset?
Thanks
And my PSU is intex 400w.
GeekyBoy is offline
Old 16-03-2009, 10:30 AM   #17 (permalink)
Goes without saying- trash the intex psu. If you are going to be stuck with onboard, you can go for VIP silver 500w or cm 390w. But if you are planning to put a graphic card in the near future- it depends on what kind of graphic you will plan to buy.
The competition for 9300 nvidia chipset is amd 790gx to be honest. Check out the conclusions yourself:
http://techreport.com/articles.x/15690/13
You can go for it, but as you see it on the conclusions- eventually you will have to get newer drivers and update bios. In this day of age, BIOS update and drivers is inevitable if one wants optimal yield and if one wants to get the machine working properly on any current systems.
Old 16-03-2009, 11:54 AM   #18 (permalink)
GeekyBoy's Avatar
Okay, thanks, But I still do want to know the price of a cheaply priced(within Rs 4000) motherboard with the 9300 chipset.
Thanks in advance.
GeekyBoy is offline
