Old 13-03-2009, 05:04 AM   #1 (permalink)
Default Need suggestions for a new comp
Need suggestions for a new system. I am planning to get a quad core cpu but not sure whether I should opt for AMD PHENOM or an intel cpu. Also what would be the best motherboard for either one, as in the best cpu mb combo? Budget around 15k for the combo.
Please advise....Thanks
EDIT: Please also suggest a good pci-e graphics card for around 3k
lubu is offline
Old 13-03-2009, 08:18 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Need suggestions for a new comp
Phenom II 920 - - Rs. 10,500
Biostar 790GX A2+ - - Rs. 5,200
Palit/Sparkle 9600GT 512MB GDDR3 - - Rs. 5,500
I suggest get a better card rather than quad core at that price.
http://pleaseguide.me/
comp@ddict is offline
Old 15-03-2009, 12:14 AM   #3 (permalink)
Rig It Up
What would be you using the system for> Gaming> Video editing?
For Intel config you can go for,
Core 2 Quad Q8200 - 8,800/-
Gigabyte EP45 -DS3L - 7000/-
I agree with comp@ddict, at least 9600gt for this config
Crossfire is offline
