| Forum |
#1 (permalink) | |||||||||||||||
Kingston 2 gb ram 800 mhz on d946gzis intel org. board. pls explain this some one.. well can this work any how .....like 1 channel or half of it. ![]() ![]() Well how can I know exact frequency of ram it's working on and what ram has
#3 (permalink) | |||||||||||||||
need answer quickly
as If any prob so I contact retailer and change My Ram
#4 (permalink) | |
Project Halcyon V2.0
The RAM is running at 667MHz, since its DDR2 the effective bandwidth is twice the value shown by CPU-Z(333MHz*2=667MHz), max bandwidth is 400MHz*2=800 MHz. But your mobo supports 667MHz max, so you can't get 800MHz(400MHz*2) out of it, no need to change RAM. To get dual channel mode you need two RAM modules inserted in the two RAM slots, the RAMs must be identical to get good performance.
[i7 2600k|Asus Z68 VPro |Vengeance 2x4GB|MSI GTX580 Lightning][TX 750v2|Seagate 500GB+WD Black 1TB|CM HAF 912 Adv] [APC 1100VA|Siberia V1|PL30|X360 Controller|Noctua U12PSE2] [G500|G110] Adata SH14 Review(Digit Forum): http://tinyurl.com/842vpx6 |
#5 (permalink) |
DDR=Double Data Rate.
PC2 6400(400MHz) that means double it 2*400mhz=800mhz you are using ONLY 1 RAM right?then Channel#Single is correct. when you use 2 ram modules in the alternative slots it activates DUAL CHANNEL. and your RAMs are working in 800mhz
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90 |
#6 (permalink) |
No, they are working in 667MHz, take a look at the 1st screenshot, it reads the current timings, the second screenshot reads all the available timings.
#7 (permalink) | |||||||||||||||
thanx Guys knew this but was very confused and wanted second opinion
thanx a lott guys
#8 (permalink) |
@tkin
oh yes..sry my bad.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
