Old 12-03-2009, 11:38 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Smile Backup desktop files to laptop using ethernet cable possibl?
I need to backup my data from my old HDD of my desktop to a laptop(Dell Studio 15) and then transfer it back to my new HDD. I'm doing this circus because suddenly my mobo is not detecting both the HDDs together. Is it possible to just connect using an ethernet cable and start backing up files or should I use a hub? I'm thinking of getting my friend's BSNL 4 port ADSL router in case I need to use a hub. Once I connect it to the laptop, what is the procedure to find the desktop, if any?
Want to make this world a better place? Then, start seeding and don't be just a leecher
phreak0ut is offline
Old 13-03-2009, 03:52 AM   #2 (permalink)
Default Re: Backup desktop files to laptop using ethernet cable possibl?
Yes, you can network your laptop and desktop without a hub. Just use a crossover LAN cable to connect the two together. This is a cable where the individual wires to some of the pins in the two RJ-45 jacks are interchanged. Your local computer shop may have such a cable readymade or you can ask them to make one for you. It's quite easy.
Details of the actual settings for networking depends on the OS. This should be available in previous threads. Do a search first and ask again if there's something you don't understand.
pimpom is offline
Old 13-03-2009, 04:00 PM   #3 (permalink)
Project Halcyon V2.0
tkin's Avatar
Do you have BSNL broadband? If your modem is connected to PC via LAN then you can use that cable. Else just go to shop and buy a LAN cable, costs about 100/-.
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Black 1TB|CM HAF 912 Adv]
[APC 1100VA|Siberia V1|PL30|X360 Controller|Noctua U12PSE2]
[G500|G110]
Adata SH14 Review(Digit Forum): http://tinyurl.com/842vpx6
tkin is offline
Old 13-03-2009, 05:26 PM   #4 (permalink)
phreak0ut's Avatar
@pimpom-I'll be backing up from XP to Vista. I'll check out for the threads.
@tkin-I'm on BSNL. So, I've got the cable
