Old 12-03-2009, 09:10 PM   #1 (permalink)
Post building a power saving pc
Hi
I want to build an e-pc (which save energy as much as possible). But my requirements are as under 8)
6 No of SATA ports must
1 LAN port
Wi-Fi
4 No of DDR-2
Can any one suggest me best power saving motherboard and processor???
idesigns is offline
Old 12-03-2009, 09:38 PM   #2 (permalink)
Rig It Up
Default Re: building a power saving pc
What is your budget?
The 45 nm Intel processors are power saving ones.
If your budget is low, i would recommend Intel e5200, the most VFM 45nm processor, costs 3300/-.
About the mobo, I know of some Asus motherboards that have onboard wifi but don't remember which one...will let you know soon...
Crossfire is offline
Old 12-03-2009, 10:17 PM   #3 (permalink)
which PSU did i use ???
My budget is Rs.10000 to 15000.
Cheaper than that preferable
idesigns is offline
Old 12-03-2009, 10:59 PM   #4 (permalink)
The Sorcerer's Avatar
Why not- Get that atom motherboard, rams and a psu- something like vip 400w silver (fsp foxtron oem which has active pfc)/cm extreme plus 390w (doesnt have active pfc though) and a WD green hard drives? Not sure how much sata ports they have though. Or else cheap a cheap amd board+ amd x2 proccy!! AMD processors is much energy efficient in idle and load as far as seen.
The Sorcerer is offline
