Old 11-03-2009, 12:22 PM   #1 (permalink)
napster007's Avatar
Default Portable HDD problem
I've been facing a small problem these days. I had bought a new transcend storejet 160gb external HDD a few months back. In past one month or so... my drives got corrupted and i had to format them. I advocted that since the HDD was being connected to systems carrying some real nasty viruses. But even after formatting the disk and not connecting it with infected systems, sometimes it is developing problems like not being able to copy from the disk givig the CRC data redundancy check error and stuff.
Is there a solution? Or do i have to get it exchanged?
An early reply is appreciated as i'll be leaving town soon!
napster007 is offline
Old 11-03-2009, 12:27 PM   #2 (permalink)
Searching...
Default Re: Portable HDD problem
Well get it exchanged if you can! My cousins Seagate 500GB HDD too was giving the same trouble. He got is replaced from the dealer.
At least take it to the dealer and show him your problem so that in future he can't get away with 'It's your fault' answer!
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 11-03-2009, 12:29 PM   #3 (permalink)
napster007's Avatar
do i have any alternate solution?
Old 11-03-2009, 12:44 PM   #4 (permalink)
The Sorcerer's Avatar
Google for hd tune and install it. Run error scan on the external hard drive and see if it has bad sectors. If it has bad sectors, give the drive to your dealer and ask for replacement.
The Sorcerer is offline
