Old 10-03-2009, 03:48 PM   #1 (permalink)
Pro Geeks
Micheal's Avatar
Exclamation How to connect PC with a BRAVIA TV ?
I have some movies on my hard drive, some in DVD format, a few in VCD format and others in HD format. Now I know you will say that I can burn them onto discs and watch it using a DVD player. Now although it is feasible (to some extent) it is not at all possible for the HD movies (well atleast those encoded with the Matroska codec). I dont have a DVD player and dont want to buy one, coz they are useless. Next i dont want to increase my collection of disks.
So, please tell me a method people how to connect my computer with a bravia tv. Here's the details:-
CPU~
Asus P5Q;
Intel C2D E8400;
CM 500W Extreme Power Plus PSU;
LG DVD Writer;
1 X 1GB Transcend DDR2 667MHz RAM module;
2 X 1GB Corsair XMS2 DDR2 800MHZ RAM module;
Samsung 80GB HDD (SP0812C);
Western Digital 320GB HDD (WD 3200AAKS);
XFX 8600GT 265MB DDR3 graphics card;
[PS - whatever anomalies you see in the setup was due to budget constraints, not going into details]
TV~
Sony BRAVIA KLV-26S400A
see it for yourself: http://www.sony.co.in/product/klv-26s400a
Now i have been able to hook these up using the monitor cable but then there is no sound output. Please give me a solution. I can go for shopping only till this Friday.
[sorry again. i live in kolkata. so most probably will be shopping in chandni]
Micheal
Status: Digitized since 2004
Micheal is offline
Old 10-03-2009, 11:47 PM   #2 (permalink)
Default Re: How to connect PC with a BRAVIA TV ?
Hi dude, i have a Bravia 32" LCD TV (KLV32V400A) which has a wide variety of inputs. I have successfully connected the same with my pretty old Rig(P4 HT 3GHz, 2GB RAM, 8400GS Graphics card). I know it can't play full HD but it sure plays 720P which is acceptable. The best way to go about this is as follows:-
1) Get a DVI - HDMI Adapter. You will get this in 200-300 bucks i suppose. This looks something like this
http://www.avocent.ca/img/product_im...adapter-lg.jpg
i suppose you can't get audio through this, although newer cards have this facility.
2) if you motherboard has optical out then use it, otherwise get a normal cable which connects to line out of your PC to Audio Left and Audio Right on the back of your TV(Stereo sound)
3) Get the updated drivers for your graphics card.
You can get the above mentioned components on ebay as well.
sohancool is offline
Old 11-03-2009, 06:49 AM   #3 (permalink)
Pro Geeks
Micheal's Avatar
if i go for the dvi-hdmi convertor, i will have to buy a hdmi cable which is a costly affair. plus where can i get these, i dont kno, atleast of decent quality.
about option 2, yes i do have optical SPDIF port if thats what you mean. i like this option. seems feasible. but what i really want to know is that what to ask the dealer considering that most dealers dont do their homework. do you know any particular shop
Micheal
Micheal is offline
Old 13-03-2009, 01:38 PM   #4 (permalink)
How about eliminating all these cables and go for a lacie HDD ?
http://www.lacie.com/asia/products/p....htm?pid=11154
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 14-03-2009, 01:14 AM   #5 (permalink)
Pro Geeks
Micheal's Avatar
ya thats a lot of help
blacklight you brought me back to the same thing --- CONNECTORS
Micheal
Micheal is offline
