Old 10-03-2009, 10:04 AM   #1 (permalink)
Thumbs down Transferring video from Sony DCR TRV 285E to PC
Hello guys...
I need to transfer videos from the mentioned cam to pc.Do i need a firefwire card ? wont usb do...?
Tried using USB but video is small resolution in sony picture packge ...also tried in pinnacle but video is of high res 720X480 but very blurry and soft looks like upsaceld 320X240 video.
If using fierfire what software shoudl be used to tranfer the video ..?
can someone who already has this camera upload a small clip of highest resolution to video hosting sites so as to check for quality.
Thanks...
Xmen360 is offline
Old 19-03-2009, 02:59 AM   #2 (permalink)
www.VideoEditingIndia.com
VideoEditingIndia's Avatar
Default Re: Transferring video from Sony DCR TRV 285E to PC
There is no much difference between a firewire and USB 2.0 capture. And almost there is nothing to do about quality in video capture medium unless you are dropping frames.
The quality degrades because of the Codec. Which codec you are using to capture the video and Which software?
Try this software and use DV Type 2 codec to capture: http://paul.glagla.free.fr/captureflux_en.htm
TATASafariClub.com - Its only for MEN - News, Tips, Photos & Guidelines for Men!
VideoEditingIndia.com - Film, Audio, Video Editing & Compositing - Get movie Night Right!
VideoEditingIndia is offline
Capturing videos with my sony handycam dcr trv 285e rohanravi26 Software Q&A 3 14-10-2008 01:52 PM
sony product query reg. video legolas Software Q&A 3 20-01-2007 09:14 PM
video capture using usb in sony handycam shivi4 Cameras and camcorders 18 16-07-2006 03:36 PM
sony hanycam video capture shivi4 Hardware Q&A 1 17-06-2006 02:03 PM
