Old 08-03-2009, 06:12 PM   #1 (permalink)
Good Boy
george101's Avatar
Question upgrade dell s1909w to samsung 2233???
guys am currently using dell s1909W and i find it small compared to normal widescreen monitors of 16:10 ratio. but i like 16:9 ratio better as am more onto games and movies and surfing with multiple tabs open. shud i go for samsung 2233, as my dealer says its available for Rs.10,133/-.
he says he wil take my dads monitor which is viewsonic 1903w for 5k. shud i go for it???
btw how is the clarity of samsung? i feel dell is much superior to viewsonic in terms of clarity, is samsung as good as dell??
george101 is offline
Old 08-03-2009, 06:26 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: upgrade dell s1909w to samsung 2233???
85% of the dell's screens are made by samsung- others are like sanyo and other manufacturers. However all the dell screens are designed by dell's specifications themselves. In other words, even though 85% of the dell screens are made by samsung, it isnt anything like samsung screen. Choice needs to be made based on model number- not brand. Technology and electronic goods shouldnt be bought based on brand- doesnt work that way . I think you get Benq T2200HD @ 10K most probably. You also get Benq E2200HD for around 11k-12k.
The Sorcerer is online now
Old 08-03-2009, 06:31 PM   #3 (permalink)
Good Boy
george101's Avatar
hows the quality of benq? the prob is samsung is readily available here whereas benq is not? thats y i thot of going for samsung? can u plz comment on samsung 2233?
Old 08-03-2009, 06:43 PM   #4 (permalink)
Some said its good- some say its pretty mediocre. But it should satisfy majority of the users. In any case, all LCD screens needs manual colour calibration which many end users dont do usually. Benq makes fantastic screens and dvd writers over the years. Just as an FYI- E2200HD looks well only on native resolution and T2200HD looks bit better then E2200HD on lower than native resolution- but the source of the picture is as important of the screen as well. You can get the screen from others cities. Many reputed sellers do ship to other cities. Check out primabgb.com or lynx-india.com if you don't get screens over there. BTW which city do you live? Maybe others who are here and at your city *might* help you out to find other sellers. Personally I would be better off buying stuff personally which is based on sight and sound, but there are certain products which are really good that can be bought with complete trust.
Old 08-03-2009, 06:56 PM   #5 (permalink)
Good Boy
george101's Avatar
am frm kerala, no matter which city u wnt get anything here except ernakulam/cochin. btw r u using benq?
Old 08-03-2009, 07:22 PM   #6 (permalink)
Mine is an old Dell E2208wfp I reviewed ages ago with ati 4870 IGB ddr5 as the source. As I said, these sites I mentioned do nationwide shipping.
Old 08-03-2009, 09:14 PM   #7 (permalink)
RMN
you will struggle to find Benq models in EKM too...
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 08-03-2009, 09:55 PM   #8 (permalink)
Stick to dell 1909 model. Save money and try to get an s-ips panel in the future. Dont ditch a TN panel to buy another TN panel just because of the size.
Old 10-03-2009, 11:16 AM   #9 (permalink)
Good Boy
george101's Avatar
do u really think i shudnt go for 22 inch? am really confused now?
Dell S1909W Monitor Zen Hardware Q&A 4 30-12-2008 07:33 PM
Dell s1909w or Viewsonic 1903wm???? george101 Hardware Q&A 1 28-11-2008 11:19 PM
LCD: Samsung or Dell?? rhitwick Hardware Q&A 6 26-03-2008 10:46 PM
Samsung Ships SATA II Flash Drives to Dell Cyrus_the_virus Technology News 2 19-02-2008 09:26 PM
