Old 07-03-2009, 08:10 PM   #1 (permalink)
Default Combo Drive problem
I have been using Mercury combo drive since october 2005. for the past few months whenever i try to get a cd burned, the burning process gets aborted halfway spoiling the CD. of late the burning process gets terminated in the beginning itself. It displays error as power calibration error. What should i do. Should i discard my combo drive and get a new one...?. i have also included a screen shot .
manoj_mafiosi is offline
Old 07-03-2009, 08:23 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Combo Drive problem
Post the screenshot using: http://www.tinypic.com/
Also what CD Media you are using????
- MrinTech :)
mrintech is offline
Old 07-03-2009, 09:30 PM   #3 (permalink)
The Sorcerer's Avatar
Are you using windows xp with service packs by any chance? Some of the updates are known to make ran DMA/PIO conflicts. Not necessary that this IS the possibility- its just one of them which is common but most often overlooked in forums. Good burn also depends on discs and writing speeds as well. Crappy Tier 2 discs like moser baer Made in India ones are pretty sad ones to use to constantly burn.
The Sorcerer is online now
Old 07-03-2009, 10:25 PM   #4 (permalink)
RMN
try reducing the write speed,if it works that is probably because the CD/DVD's are of low quality.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 19-03-2009, 03:41 PM   #5 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Try to clear the lens of the drive, using lens cleaner CD and then try.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Problem with DVD Combo Drive gamer669 Hardware Q&A 1 22-04-2008 11:17 PM
Combo drive problem Rajasekaran43 Hardware Q&A 2 13-08-2007 02:45 PM
DVD Combo Drive Problem dkverma87 Hardware Q&A 1 12-04-2007 03:19 PM
combo drive problem again gau_pppu Hardware Q&A 2 21-12-2006 10:00 AM
problem with combo drive gau_pppu Hardware Q&A 4 25-11-2006 09:32 AM
