Old 07-03-2009, 01:01 PM   #1 (permalink)
Default New CPU @20K
Hi All,
I am planning to assemble a new PC. My budget for the CPU (processor, mob, ram, power supply, cabinet, HDD, DVD drive) is 20K.
I would like to buy Intel processor and mob.
I had short listed following thing:
Processor : Pentium Dual-Core E5200
MOB : Intel MOB with G33 or G35 chipset (I liked the DP35DP mob from intel but only down side, I felt, was it does not have onboard graphics. I am trying to avoid buying an separate graphic card.. )
RAM : 4 GB DDR2
HDD : 320 or 500 GB (either Seagate or WD)
PSU , Cabinet , DVD drive ????
I am trying to build my system around above configuration.
I need your suggestions in assembling the CPU (I will be using my existing monitor, keyboard etc..)
The only constraint is my budget…20K…… and processor and mob must be from Intel..
Thanks,
McDon
mcdon is offline
Old 07-03-2009, 05:22 PM   #2 (permalink)
Default Re: New CPU @20K
E5200 - 3.5k
DG35EC mobo - 4.55k
2x2GB RAM - 2.2k
320GB HDD - 2.5k
Sony DVD Writer - 1.1k
Decent PSU+Cabinet - 2k
Total is 15.85k
You can either up the proccy or get a basic gfx card... If you want to do some gaming or any gfx stuff, it is better to get a basic gfx card...
Arun
sakumar79 is offline
Old 07-03-2009, 06:39 PM   #3 (permalink)
Thanks for ur reply.
Do i need to buy a 500W PSU or a 400W PSU will do?
mcdon is offline
Old 07-03-2009, 07:19 PM   #4 (permalink)
400W Should suffice for this rig, but better to go for 500W for future proofing in case you plan to upgrade with gfx card, etc...
Arun
Old 12-03-2009, 06:53 AM   #5 (permalink)
Rig It Up
Smile Re: New CPU @20K
Gigabyte G31-S2L 2400/-
Intel e5200 3500/-
Corsair XMS2 2GB 2200/-
This motherboard can overclock like hell, get a nice CPU cooler to overclock better..
Posted again:
Also can get VIP 500W with passive PFC for approx 1850/-
Crossfire is offline
Old 12-03-2009, 07:40 AM   #6 (permalink)
toofan's Avatar
Processor: Intel C2Duo E7300 Rs 5500.00
Mobo: MSI P35Neo F: RS 4500.00
RAM: Kingston 2Gb 800Mhz : Rs 1200.00
HardDisk : Segaet 500GB: Rs 2900.00
Cabinet: Zebronics Bijli : Rs 1600.00
DVD Drive: Rs 1100.00
Graphic Card: Palit 8600GT 512Mb DDR3 : Rs 3500.00
Total: 20300.00
Here you can exceed ur budget for just Rs 300 or you can look for a cheaper Mobo and increase the ram or Graphic Card.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 12-03-2009, 07:19 PM   #7 (permalink)
toofan's Avatar
you can look for other mobo at same price range if its not become an old choice.
Check my work at:
toofan is offline
