Old 06-03-2009, 08:52 PM   #1 (permalink)
Default Suggest a motherboard
I need a mother board which have -
1. PCI-E
2. 4 Sata slot
3. No onboard grafics
4. 4 ram slot
5. chipset either nvidia or intel
6. any brand easily available
7. price limit 3000 rs
8. Bus speed 1333 mhz
Need help urgent. thanks in advance.
kuki_295 is offline
Old 06-03-2009, 08:55 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Suggest a motherboard
For which processor do you want?
desiibond is offline
Old 06-03-2009, 09:14 PM   #3 (permalink)
Core 2 duo
and 800 mhz ram
kuki_295 is offline
Old 06-03-2009, 09:19 PM   #4 (permalink)
The Sorcerer's Avatar
What about the budget and th rest of the config?
Hardware BBQ
The Sorcerer is online now
Old 06-03-2009, 09:37 PM   #5 (permalink)
1. PCI-E
2. 4 Sata slot
4. 4 ram slot
See the first post
kuki_295 is offline
Old 07-03-2009, 01:18 AM   #6 (permalink)
^^ you mentioned slots. You havent mentioned processor and other components.
Hardware BBQ
Old 07-03-2009, 01:28 AM   #7 (permalink)
1. PCI-E
2. 4 Sata slot
4. 4 ram slot
Core 2 duo
and 800 mhz ram
this dude only need the motherboard
realdan is offline
Old 07-03-2009, 10:24 AM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
what the
what motherboard he needs , he dint tell us what components he has
May be this DUDE has some secrets abt his config
damngoodman999 is offline
Old 07-03-2009, 10:51 AM   #9 (permalink)
How hard can it be to mention other components? Fine take any G31 chipset board but blame us if they have compatibility issues with other components since you are not making any efforts to mention it. There are people who will just give advice for the heck of doing it and if you get your upgrade into trouble because of some compatibility issues, they will care a damn- this does not mean by giving advice.
But there are people who are ready to help to get the best possible solution to make sure that you take a proper board which is compatible with your existing components- this is what it really means to give advice. So I am sure if realdan reads this, he would agree it as well.
Hardware BBQ
Old 07-03-2009, 11:33 AM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Core 2 duo
and 800 mhz ram
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 10-03-2009, 01:56 AM   #11 (permalink)
Sorry all
actually a friend of mine wanted a new motherboard and procy
he already have intel DG31GL mobo and Intel Celeron 430 processor and he is gonna sell them and wants a new mobo and processor he is also gonna sell his spare 160 gb hdd and a dvd writer and will spend about 2500 cash.
reasons why he wants new mobo - no PCI-E and only 2 hdd sata slots
He is gonna buy a gfx card in future.
So he choose Intel DG41TY mobo and some 2.8 ghz dual core(i don't know why he is buying it) but the local retailer says the DG41TY is not available, so he is looking for another mobo now i think DG35EC will do his job and DG31PR is also good for him.
another question does core2 duo have lower performance per price than dual core?
and how important is FSB speed as he is shouting like "FSB speed is most important for performance"?
kuki_295 is offline
Old 10-03-2009, 02:13 AM   #12 (permalink)
damnbadman666
what a humor , no dude core2Duo architecture is best . dual core is OLD
FSB is also considered for performance but not that alone
Check the L2 cache and clock speed
L2 cache size is important
Dont worry these are lower end motherboards , worth for low level performance unless he ll not overclock with this INTEL boards
Old 10-03-2009, 03:03 AM   #13 (permalink)
Yeah i also thought same but the idiot shop guy said core2Duo is not worth the money.
Naa he won't overclock. so these mobo's should be ok
Thanks for replying
kuki_295 is offline
Old 10-03-2009, 05:54 AM   #14 (permalink)
damnbadman666
anytime Dude !!
Please Suggest Motherboard etc. vinay_001 Hardware Q&A 2 17-03-2008 12:03 AM
Suggest a motherboard catchjaga CPU / Motherboards 3 11-08-2006 11:45 AM
Plz Suggest any Motherboard for 2.8 HT niggers Hardware Q&A 4 20-05-2006 09:21 AM
AMD motherboard !!!! Plz suggest sidewinder CPU / Motherboards 1 26-10-2004 12:00 AM
