Hello,
I have a "ancient" pc which I bought in 2002. Its a Compaq Presario.
I want to upgrade it and seek suggestion on the same.
Details are given below:
Specs:
Pentium 4, 1.56 GHz, 20-GB HD (maxstor), 128MB SD-RAM, intel945 (mother board).
15" Compaq CRT monitor, JBL platinum speakers, APC UPS.
Software:
XP(home) NO Service Packs, NO AV. Does not support USB 2.0 etc
Embellishments:
I have added a SONY DVD-R/W drive, SONY CD-R/W, 160 GB Seagate HD.
All the above devices are IDE.
Currect Use:
I use my pc to watch movies,listen to songs, play games like AOE,NFS5 etc
and connect to the Internet using dialup (once in a blue moon).
Future Use:
Intend to take a broadband connection, which means I need to install all the service-packs, AV, Firewalls etc.
Requirements:
I want my PC to be usable for atleast a couple of years.
Also the motherboard should support the latest USB/SATA etc. standards and at the same time be flexible for future additions.
Another requirement is all my current IDE devices should function.
Please suggest a good motherboard which would serve my purpose above.
Since I am changing my motherboard do I need to buy a new cabinet also?
Should not 1 GB of RAM suffice? Which brand of RAM to buy? (MHz?DDR?DDR2 etc etc).
Which processor should I opt for?
My budget is around 10,000 - 12,000.
Any suggestions on what to do with the old-cpu?
