05-03-2009, 05:41 PM
Gaming LCD monitor
Hello Guys,
Firstly of all i m sorry to start a new thread for this...But was not able to find proper answers for the query I have...
Now then since when I have upgraded my system and now have the 4870 card...I have been very much willing to buy a LCD as I am still stuck on a 17' crt monitor(LG studioworks). But at the same time I have some queries too which is stopping me to buy that...so putting in a query here.
Will it really make a large difference in visual quality if I switch to LCD? I have heard many time that for gaming a CRT monitor is better?
Even if I have to switch to a LCD which will be good for gaming? my budget is 12k max. 20" inches will do
Thanks in advance...
MY PC >> E8400|intel G45ID|MSI N560GTX-TI Twin Frozer II/OC|2gb ram|500GB HDD|22" Samsung LCD|Corsair Power 650TX|NZXT Guardian 921 RB|
05-03-2009, 06:13 PM
Re: Gaming LCD monitor
there is no prob with such a thread...
since you have a 4870 you can easily get a good 22 inch monitor for your budget may be even 24.
Benq 22 " E2200HD FULL HD =11750Rs
do check the reviews.
and btw i guess today's LCDs offer the same or better quality as CRT
update
T2200HD(lacks HDMI1.3 / Audio in / Headphone Jack compared to E2200HD) is 9975RS
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
Reason: Automerged Doublepost
05-03-2009, 06:35 PM
Thanks a lot RMN... do let me know if you get any more info
05-03-2009, 06:42 PM
damnbadman666
E2200HD is good , T2200HD also works good is there any one using the monitor speakers u ll die if u hear frm that
especially for HDMI -> DVI is common is gr8 for games so go for T2200HD
But please instead of the T2200HD go for the Samsung t220 full HD it is very gr8 one u wont disappoint with this check the reviews
05-03-2009, 11:56 PM
Hey r u sure T220 is full HD coz on samsung site its resolution is given 1680 x 1050. And nowhere they mentioned its full HD.
06-03-2009, 12:09 AM
I have Samsung T220. It's great and got very good specifications life 2ms response time and 20000:1 contrast ratio. The maximum resolution is 1680x1050 but that's more than enough for most of the games. 1920x1800 would beat the living hell out of your graphics card unless it's the GTX series or 4870.
Also Samsung T220 is a visual treat. It's really eye catching. I would anyday prefer Samsung T220 over BenQ E2200.
06-03-2009, 12:25 AM
Hey i just found out they hav displayed T220HD on usa site. Not on india's site. Wich is urs T220 or T220HD. I m planning to buy. I hav short listed 2233SW, T220, and T2200HD. Any model from dell ?
06-03-2009, 09:26 AM
Bond, Desi Bond!
http://www1.ap.dell.com/content/prod...sd1&l=en&s=bsd
Dell 2009W (2000:1 (typical) contrast ratio, 5ms response time, 1680x1050 resolution)
Dell UltraSharp 2209WA( IPS panel, 178/178 viewing angle which is rare for LCD's)
06-03-2009, 11:25 AM
Samsung 2233 SW at Rs.12K.
Pros:
Full HD, 22inch, VGA & DVI Input & good looks.
Cons:
No HDMI
06-03-2009, 11:52 AM
I would say if you are looking for Gaming on 1920x1080 then go for BenQ E2200HD. 12k is a good price for a 1920x1080 LCD with HDMI. I had also inatially considered buying Samsung T2200 HD but at time I bought BenQ(3-4 months back) the reason I bought BenQ was my budget was 12k too and samsung was selling at around 15k at that time.
If you are looking for best bet at 12k w/o HD/HDMI then go for samsung T220.
Core i7 920,Gigabyte EX58-DS4,OCZ 3X1GB PC10666 triple channel DDR3, Palit HD Radeon 4870 1GB, CM690, CM Realpower 700W,BenQ 22"
06-03-2009, 12:06 PM
Bond, Desi Bond!
^^see, first of all BenQ is no match to Samsungs and Dell's models. It has Color gamut problem.
Samsung T220 too is not a great monitor.
06-03-2009, 02:31 PM
how is BenQ service compared to Samsung and Dell?
07-03-2009, 11:50 AM
The question remains the same...which one should i go for then  ...if not benq...or should I stick back to gud old CRT for a while
07-03-2009, 12:23 PM
EXIT: DATA Junkyard
Go for BenQ right away^^^^^^^^^^^^^
07-03-2009, 02:42 PM
Tech addict
Ya I'm using BENQ T2200 HD giving me great performance for price I paid for it and it is dust cheap nowadays around 9.5k apx.
Remember neither dell 2209W nor samsung T220 are full HD. BTW DELL 2209W is best performer under 15K if full HD is not prime consideration.
11-03-2009, 10:26 PM
Thanks to all of your wonderful replies and suggestions. Will surely let you know once I buy it.
12-03-2009, 06:46 AM
Rig It Up
My suggestion is go for Samsung T190 with 2ms response time for 10300/-..(IT wares)
12-03-2009, 09:33 AM
damnbadman666
Gr8 19"inch monitor for 10K
Benq T2200HD is available for 9.5K its better tan the best
12-03-2009, 09:56 AM
#19 (permalink)
Bond, Desi Bond!
NO. I would spend 11k on Dell/Samsung 22" models than spending 10k on a 19" display. Dell 198WFP retails for 7k and it's far far better than T190.
16-03-2009, 09:43 PM
#20 (permalink)
Good Boy
is samsung 2033sw or samsung s1909w better? not abt price but quality wise.
20-03-2009, 04:44 PM
#21 (permalink)
Hey guys what about Samsung 2233sw...its editor choice in techtree and they have clearly mentioned it to be far better than Benq E2200HD
http://www.techtree.com/India/Review...062-630-2.html
i am confused..shd I finalize Samsung 2233sw ...its costing 10.5 K and my lg studioworks 17" will go for around 2000 i guess ...so it will be a gud deal for 8K. what say?
20-03-2009, 06:28 PM
#22 (permalink)
Bond, Desi Bond!
^^yes. true. it's a terrific model.
21-03-2009, 04:04 AM
#23 (permalink)
Point Blanc
good model,
as desi said earlier benq models are good value for price model not the best of the ones available in the market. see in what price are you getting Samsung 2233sw.
you never mentioned your budget for the ordeal
22-03-2009, 09:21 PM
#24 (permalink)
Guys me 2 wanna buy samsung 2233sw primarily for cheap alternate for hdtv.Coz i m gonna buy ps3/x360 in 2-3 months.Will absence of hdmi be problem?Thanx.
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
22-03-2009, 09:47 PM
#25 (permalink)
^Get VGA to HMDI converter cable.
22-03-2009, 11:08 PM
#26 (permalink)
Super Saiyan
Nice info.
I am just a reader of ur post.
Peace Out~~~!
Newest Purchase :- Razer Deathadder 3.5G and Razer Speed Control Goliathus Mouse Mat.
23-03-2009, 09:20 AM
#27 (permalink)
Hey guys does it require high end pc to run 22"lcd?I have p4 3ghz,xp sp2,1 gb ddr ram,nvidia 7300gt.
23-03-2009, 01:44 PM
#28 (permalink)
^It should work fine, but do not expect to do gaming on full HD.
23-03-2009, 06:39 PM
#29 (permalink)
I just wanna use lcd monitor as substitute for hdtv.I want to use it mainly with x360/ps3 .As for its use as pc i will use for movies and photo editing with adobe ps cs2.
23-03-2009, 06:55 PM
#30 (permalink)
whats the problem in gaming on full hd monitors ?? doesnt support resolution? or something else?
