Old 04-03-2009, 06:30 PM   #1 (permalink)
Rockstar In Nothing
Default TV Tuner
Hi
i am going to buy a TV tuner card . Please tell me the card card will give me the same picture quality like my TV gives me or , will give me better or worse then the TV.
If it depends on card then my budget is 1k give me some suggestions . i have cable connection not a DTH .
Thanks
Intel Pentium D 2.66 Ghz
1Gb Ram running at 533 Mhz
Intel 102 motherboard
Hitachi 160 GB HDD,Segate 40 Gb Hdd
Lg DVD Writer & Lg cd writer
15" Color Moniter
ankurya1985 is offline
Old 04-03-2009, 08:16 PM   #2 (permalink)
RMN
Default Re: TV Tuner
take a look at this thread
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 06-03-2009, 07:40 PM   #3 (permalink)
Rockstar In Nothing
Hey thanks but a doubt remain the same .
If i will buy a cheap TV tuner card like INTEX so is there will be some difference of picture quality .
15" Color Moniter
Old 06-03-2009, 07:47 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
First question is do u want internal or external??
If u r buying external then u can go for intex, mostly in external tv tuner cards quality is good only. But if u r buying internal, then u can go for PixelView Play TV Pro 3. I have it and the best picture quality + radio also(fm). And yes best VFM.
Blogging at:
Technostarry
saqib_khan is offline
Old 06-03-2009, 07:56 PM   #5 (permalink)
Rockstar In Nothing
actually i was hoping to buy an internal card if external card is better than internal then i will go for them & also i want to record programs . I am using a cable connection but later i want to use it with DTH like BIGTV so it should be compatible with that .
BTW what is th price for PixelView Play TV Pro 3 ???
15" Color Moniter
Old 06-03-2009, 09:28 PM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
Price is around 1100/-
If u r going for internal then definitely go for this card. I m using this and satisfied.
Blogging at:
Technostarry
Old 06-03-2009, 10:35 PM   #7 (permalink)
Rockstar In Nothing
thanks i will surely go with it
15" Color Moniter
TV Tuner within 1.5k channabasanna Hardware Q&A 8 06-11-2008 04:47 PM
Best Tv Tuner CyCo QnA (read only) 3 20-05-2006 07:35 PM
tv tuner help shaunak QnA (read only) 4 03-05-2005 10:45 PM
