Old 03-03-2009, 11:30 PM   #1 (permalink)
ANURAG SHARMA's Avatar
Wink Low end budget PC for net surfing
Plz suggest me a Low end budget PC config for surfing net and office apps. As i need to install a cyber cafe.
BE THE BEST EITHER HACKED IN THE QUEST
ANURAG SHARMA is offline
Old 04-03-2009, 12:17 AM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
Smile Re: Low end budget PC for net surfing
Get Second P III 800mhz with 256 Mb ram and then use Deepfreeze and you are good to go.Anything more is waste of money.
You can use the recent CPU's any of them as a Server.
And please do not skip on good Lan Port Switch.Never use any thing less than D-link.
Best of luck.
freshseasons is offline
Old 04-03-2009, 05:30 PM   #3 (permalink)
Point Blanc
Default Re: Low end budget PC for net surfing
what is deepfreeze
acewin is offline
Old 04-03-2009, 08:49 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Why don't you order nettops.
THey are based on ATOM. And they barely take any power or space. And for netsurfing and business(power efficient), they are the best.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 04-03-2009, 08:49 PM   #5 (permalink)
ECE0105's Avatar
Check this out
http://en.wikipedia.org/wiki/Deep_Freeze_(software)
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 04-03-2009, 08:52 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Wikipedia does not have an article with this exact name. Please search for Deep Freeze (software in Wikipedia to check for alternative titles or spellings.
About me:
Old 04-03-2009, 11:01 PM   #7 (permalink)
PC Addicted
comp@ddict is right.
nettops or Small Form Facor PC should be just right.
Playing hack-n-slash games using keyboard+mouse is injurious to both of them.
G33K n G4M3R is offline
Old 05-03-2009, 03:04 PM   #8 (permalink)
Best of luck.
Thanx for ur nice suggestions....I will definitely put on....and can tell me some more about deepfreeze.
from where i cud get these nettops
Last edited by ANURAG SHARMA; 05-03-2009 at 03:06 PM. Reason: Automerged Doublepost
Old 05-03-2009, 09:05 PM   #9 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
That's the only think that I'm not sure about^^^^ sorry
About me:
BUDGET!!!!!!!!!!!! shyamno Mobiles and Tablets 2 12-06-2007 11:16 AM
budget 70k suhas_sm Hardware Q&A 7 25-09-2006 08:35 PM
Low budget PC under 15K montylee Hardware Q&A 19 29-08-2006 09:14 AM
Which one???65-70k budget. diabolic_saint QnA (read only) 13 21-09-2005 06:48 AM
