Old 03-03-2009, 01:10 PM   #1 (permalink)
Dust in the Wind
Skud's Avatar
Default Where is Overdrive?
recently i purchase a palit radeon hd4850 and install the version 9.2 of catalyst driver. however, i couldn't find neither the overdrive menu nor the option to enable it in CCC.
even the driver bundled with the card didn't show it.
plz help.
Skud is offline
Old 03-03-2009, 01:38 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
Default Re: Where is Overdrive?
Ok do this..
First go to the ATI Catalyst control centre.
Then go to the Overdrive option which is right below Avivo Video option.
When you click on the Overdrive icon you will see the Ati overdrive option grey(means you cannot do anything)
Now do this.
Right left of Select GPU to configure you will see the lock option.Please click it and unlock it .
You will get the warning.Ignore and you are set.
More information in addition to the above.
This is right off the ATI website.
Source
a. Right click anywhere on your desktop
b. Left click on the ATI Catalyst™Control Center option
c. Click the View Menu Option
d. Select the Advanced View Option (notice the list of items under Graphics Settings)
e. Select the Overdrive™ option under Graphic Settings
f. Ensure that turn on Overdrive™ is selected
g. Click Apply
* Note: Overdrive™ is not available on all cards
freshseasons is offline
Old 03-03-2009, 02:05 PM   #3 (permalink)
Intel OCer
amitash's Avatar
use rivatuner for ocing
My site: collegeclassroom.org
amitash is offline
Old 04-03-2009, 01:15 PM   #4 (permalink)
Dust in the Wind
Skud's Avatar
Originally Posted by freshseasons View Post
Ok do this..
Now do this.
Source
g. Click Apply
Overdrive is not showing in the CCC. Below Avivo video there's VPU Recover, no traces of Overdrive.
Skud is offline
overdrive vs autocar ssk_the_gr8 Chit-Chat 11 12-05-2007 10:19 PM
