Old 02-03-2009, 06:29 PM   #1 (permalink)
RMN
Default RAM suggestion
hello guys.
i already have a 2gb DDR2 Transcend RAM@800Mhz.
i want to upgrade with a 2*2gb @800Mhz Kit.
what is the cheapest and the best 2*2gb @800Mhz module from Corsair,G Skill and OCZ.
OCing is not important and my budget is 4k MAX but would love to buy in the range of 3k!
and have DDR2 prices reduced in India?
thank you
how are these models?
G-Skill F2-6400CL5D-4GBPQ (2GB x 2) 800 MHz @ 3.2k
Corsair TWIN2X4096-6400C5(2 X 2GB DDR2 800MhZ C5) @3.3K
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 03-03-2009, 12:23 AM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: RAM suggestion
Both G skill and Corsair are gr8 brands buddy..
I myself hv a Corsair RAM (see my siggy)..
But, u can go for any of the above brands, take a RAM which has low latency..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 03-03-2009, 03:51 AM   #3 (permalink)
Freak Beta 1
Dark Core's Avatar
Wink Re: RAM suggestion
I bought 2 Gigs of Transcend 667 RAM, a couple of months back I just costed my 1600 bucks, 800 MHz should cost somewhere near
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline
Old 03-03-2009, 07:24 AM   #4 (permalink)
RMN
hmm...if im not OCing how diff will be the performance bet a transcend and Corsair/G Skill/OCZ?
ok guys help me decide between
Each module pair is tested together at 800MHz
Tested and packaged in pairs
Packaged together immediately following
system test
Tested at JEDEC standard latency settings
(5-5-5-18 )at 1.9V
SPD programmed at:
JEDEC standard 5-5-5-18 values at
800MHz
or
GSkill F2-6400CL5D-4GBPQ
CAS_Latency 5-5-5-15
Capacity 4GB (2GB x 2)
Speed DDR2-800 (PC2-6400)
Test_Voltage 1.8 ~ 1.9 Volts
PCB 6 Layers
Unbuffered
Error_Checking Non-ECC
Type 240-pin DIMM
RMN is offline
Old 03-03-2009, 07:56 PM   #5 (permalink)
Well, if NOT OCing, and as per the above 2 options (Corsair and G SKill)
Go for G Skill... as it has got less latency as compared to the Corsair one..
but yes, this is also a FACT that Corsair RAMs hv a 10Year warranty, so if i were u, i wud hv gone for Corsair....(even though the latency is a bit on the higher side)..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 03-03-2009, 08:28 PM   #6 (permalink)
RMN
Talking Re: RAM suggestion
thanks..
but both the companies provide Lifetime warranty right?
btw any idea if the model of GSkill provide those cool stickers?
and couple of Q's
-its ok to use it along with the transcend right?
-any known issues when using on MSI P45 Neo-F?
anyone!?
and how is the customer supp for G Skill?
any idea abt their service center?
RMN is offline
Old 04-03-2009, 01:41 PM   #7 (permalink)
RAMs of different brands can be used BUT BUT BUT ONLY if their Latencies match EXACTLY same.. like 3-3-3-12 or sum thing of this sort, hope ur doubt is cleared now..
also, Corsair offers 10Yr warranty on its products, i hv no idea abt g Skill man..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 04-03-2009, 05:21 PM   #8 (permalink)
RMN
i meant a Gskill/corsair kit on dual channel and Transcend on the 3rd slot.
there wont be any computability issues right?
btw my transcend latency is 5-5-5-18 and the GSkill F2-6400CL5D-4GBPQ has 5-5-5-15....that's hardly any difference right?is Gskill worth the extra money??
RMN is offline
Old 04-03-2009, 07:15 PM   #9 (permalink)
well, i think (afaik) the 15 And 18 shud also match, but i'll hv to search the net for tat...
ANd YES, G SKill or a Corsair are worth that extra bucks tats for sure buddy..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 04-03-2009, 08:20 PM   #10 (permalink)
RMN
hmmm...thanks
but are you SURE that the 0-0-0-3 lower latency would make a huge diff in Gkill/Corsair?
im sry to ask again...its just that i want to make sure the money i spent is worth while...
RMN is offline
Old 04-03-2009, 08:48 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Man get anyone of them. If you had an AMD CPU, then your need would have been one with
CAS latency - - 4-4-4-12
BTW, anyone noes of a 4GB kit with the aforementioned timings? Please tell me, post here or PM me ASAP!!!!!
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 04-03-2009, 09:25 PM   #12 (permalink)
hmmm...thanks
Dnt be sorry dude,.. well, even im not sure abt the 0-0-0-3 making a huge difference or wat,
I think the overall performance also depends on ur system specs (for these RAMs to giv ultimate performance) i may be wrong, but even im not tat expert in these things..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 04-03-2009, 09:54 PM   #13 (permalink)
RMN
thanks again..
ill probably get another Transcend itself.
btw...just curious,are there single 4gb stick for desktops?
RMN is offline
Old 04-03-2009, 10:08 PM   #14 (permalink)
I dnt think so.. u get a max of 2GB RAM stick
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 05-03-2009, 12:57 AM   #15 (permalink)
The Sorcerer's Avatar
Make sure its cl4. Seen pretty good difference on 64 bit vista sp1.
Hardware BBQ
The Sorcerer is online now
Old 05-03-2009, 08:05 AM   #16 (permalink)
RMN
will 3dsmax,maya etc work well on Vista 64bit with 4 gb ram?
RMN is offline
Old 05-03-2009, 09:23 AM   #17 (permalink)
^^ I dont see why not!
Hardware BBQ
Old 05-03-2009, 10:27 AM   #18 (permalink)
Ooh yes, ofcourse it will, without a doubt bro...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 05-03-2009, 09:14 PM   #19 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Anybody???
About me:
Old 05-03-2009, 10:00 PM   #20 (permalink)
RMN
you are looking for a 4gb kit with 4-4-4-12 timings?
G-Skill F2-6400CL4D-4GBPI
then how do we achieve the 16gb limit if only 2gb module's are available?
RMN is offline
Old 06-03-2009, 10:15 PM   #21 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Price in India?^^^^^
About me:
Old 06-03-2009, 11:40 PM   #22 (permalink)
Where hv u read this ??
Coz, on the Core i7, the max RAM supported is 12GB (2GBx6 slots)
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 07-03-2009, 02:06 AM   #23 (permalink)
@ashu888ashu88
I am afraid you need to do a lot more readings, ...am much surprised that you dont know these things despite buying the new system based on the new platform
@RMN is correct about his\her logic
just because your evga x58 motherboard only support max 12GB memory doesn't mean that it applies to all other motherboard...
for your information ASUS P6T Deluxe V2 LGA 1366 Intel X58 support maximum of 24GB of memory...
one stick of 4GB is in the market
G.SKILL 16GB (4 x 4GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad Kit Desktop Memory
realdan is offline
Old 07-03-2009, 09:50 AM   #24 (permalink)
RMN
4k at ITWares
@realdon
tnx
RMN is offline
Old 07-03-2009, 10:07 AM   #25 (permalink)
@realdan:
thanx for the update buddy, yup, im still in the process of geting to knw sum new things, I did read the review of tat Asus P6T mobo, and it jus slipped outta my mind..
@RMN: so sorry buddy, my info was incomplete..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 07-03-2009, 11:43 AM   #26 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
G-Skill
F2-6400CL5D-4GBPQ(2GB x 2) 800 MHz - - - - Rs.3000
F2-6400CL4D-4GBPI (2GB x 2) 800 MHz - - - - Rs.4000
F2-6400CL4D-4GBPK (2GB x 2) 800 MHz
- - - - - Rs4350
F2-8800 CL5D- 4GBPI (2GB x 2) 800 MHz
- - - - - 4400
Cud you tell me the difference between the four? Please anybody.
About me:
Old 07-03-2009, 12:48 PM   #27 (permalink)
RMN
@comp@ddict
im not the best at this but here you go
F2-6400CL5D-4GBPQ(2GB x 2) 800 MHz-good ram latency 5-5-5-15,bad OCer
F2-6400CL4D-4GBPI (2GB x 2) 800 MHz-very good RAM,better latency 4-4-4-12 ,better heat spreders,better OCer and you gett couple of cool stickers..OCC had a positive review.
F2-6400CL4D-4GBPK- dont know much but acc to spec i has higher volts,4-4-4-12
F2-8800 CL5D- 4GBPI
Speed DDR2-1100 (PC2-8800)
PCB 8 Layers PCB ---the others are 6 layers
and just like 6400CL4D-4GBPI has better heat spreaders and stickers.
So after countless hours of benchmarking and sweat, where do we stand with G.Skill's F2-8800CL5D-4GBPI memory kit? The F2-8800CL5D-4GBPI is sort of a mixed bag. On the bright side, with stock speeds of DDR-1100 at a miserly 1.9V, you don't have to worry about the memory not having enough voltage while booting up that you can run into with some higher voltage modules. Also factor in a supported FSB of 550Mhz, this kit should make most casual overclockers happy.
On the down side, overclocking wasn't quite what I expected out of this kit as it didn't respond at all to higher voltage and actually seemed to become more unstable if you pushed more than 1.9V into it.
To sum things up, the F2-8800CL5D-4GBPI is a good kit as long as you don't expect too much above stock speeds. However, with attractive heatspreaders and even more attractive prices of DDR2, this is a great kit to add 4 gigabytes of memory for very little dough
i say,if you are no OCing go for F2-6400CL5D-4GBPQ 800 MHz
anf if you are F2-6400CL4D-4GBPI 800 MHz
RMN is offline
Old 07-03-2009, 01:00 PM   #28 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
and if you are F2-6400CL4D-4GBPI 800 MHz
Thanks mate for that info.
And i'm for this one surely.
About me:
Old 07-03-2009, 01:07 PM   #29 (permalink)
RMN
btw just check the review
http://www.overclockersclub.com/reviews/gskill_pi_cl4/
and maybe just wait for some more suggestions...
oh
"So after countless hours of benchmarking and sweat, where do we stand with G.Skill's F2-8800CL5D-4GBPI memory kit? The F2-8800CL5D-4GBPI is sort of a mixed bag. On the bright side, with stock speeds of DDR-1100 at a miserly 1.9V, you don't have to worry about the memory not having enough voltage while booting up that you can run into with some higher voltage modules. Also factor in a supported FSB of 550Mhz, this kit should make most casual overclockers happy.
On the down side, overclocking wasn't quite what I expected out of this kit as it didn't respond at all to higher voltage and actually seemed to become more unstable if you pushed more than 1.9V into it."
frm my prev post was from a review on http://www.overclockersonline.net/?p...um=1981&pnum=8
RMN is offline
Old 08-03-2009, 12:31 PM   #30 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
RMN, this came to my mind just now. I don't need the RAM for OCing, I'm planning on the Phenom II X4 940 B.E., I'll be simply increasing the multiplier for OCing, not the bus speed.
So now where do we stand,
1. 4-4-4-12 CAS latency DDR2 800MHz
or
2. 5-5-5-15 CAS latency DDR2 1100MHz(are u sure, or is it 1066MHz?)
Note:- We have to keep in mind that the performance increase when switching from 5-5-5-15 DDR2 667MHz to 5-5-5-15 DDR2 800MHz on an AMD platform gave 6% improvement in performance.
Whereas when 4-4-4-12 DDR2 800MHz was used instead of 5-5-5-15 DDR2 800MHz, there was a phenomenal 17% improvement.
So now where do we stand, a faster DDR2 1100MHz or a low latency DDR2 800MHz, keeping in mind AMD platform favours lower latencies than higher speeds more.
That's the reason DDR3 AM3 Phenom CPUs don't give more than 5% increase in performance since DDR3 RAM latency is way higher than DDR2.
About me:
need suggestion. yash2006 Hardware Q&A 1 08-12-2008 11:53 AM
Need a suggestion for Using RAM sravan.boom Hardware Q&A 2 05-11-2008 05:43 AM
Some suggestion for n72!!!! hac_king Buying Advice 4 01-01-2008 12:50 AM
Any Suggestion for this chintan786 Hardware Q&A 1 19-06-2007 08:51 PM
some suggestion Dark Star Hardware Q&A 4 04-05-2006 06:44 PM
