Old 02-03-2009, 12:27 PM   #1 (permalink)
.NET Guru
Champ's Avatar
Lightbulb Compatible Modem/router with MTNL
Hi Guys,
I am planning to switch to MTNL Broadband and will probably use the TriB UL data-256 or TriB UL data-512 plan.
I currently owe a
1 Desktop with standard LAN etc
1. Laptop (HP DV1015tx) with std LAN and WiFi
I would like to surf Internet on both of them.
  • Can I use both computers with wireless modem supplied by MTNL if I don’t buy PCI wireless cared for my desktop
  • Which will be better (modem+PCI card) or a router
  • Which wireless modems/routers in the market are compatible with MTNL (if possible pls include market prices).
Why is it whenever someone says "with all due respect", they really mean "kiss my a$$"?
Champ is online now
Old 10-03-2009, 04:53 PM   #2 (permalink)
Default Re: Compatible Modem/router with MTNL
1. i think the wifi router should have multple LAN ports, so you should be able to connect your desktop with A LAN CABLE and the laptop wirelessly
2. difficult choice, depends on the clutter of wires and your personal preferences PLUS your budget.
3. All wireless routers are compatible with MTNL. you can try the WAG200g, retailing at almost 3k
Last edited by wishmaster.dj; 10-03-2009 at 04:56 PM. Reason: Automerged Doublepost
wishmaster.dj is offline
Connecting Modem /Router and wireless Router IANMORISON Hardware Q&A 1 19-12-2008 07:59 AM
Need Help:Hathway Cable Modem,Dataone BB Modem-cum-Router. How to Wi-Fi? awestriker Networking 1 31-01-2008 02:53 AM
Router for MTNL Triband ? shreyadr Networking 3 25-06-2006 11:42 PM
ADSL router for MTNL Triband/// anispace Networking 9 24-12-2005 09:31 AM
