Old 27-02-2009, 08:27 PM   #1 (permalink)
Exclamation powersupply info....URGENT
hi
what is the minimum powersupply needed for ati hd4870 1gb.
is 300W ok?
below is my config with approx. prices .. please advise quickly about powersupply and the below config:
config:
intel core i7 920 processer======15.5k
apacer 4gb ddr3 1333mhz ram===10k
segate 1tb sata2 3gbps hdd====5.5k
benq e2200hd monitor=========12k
sapphire/palit hd4870 1gb gpu====16.5k
integrated hd 7.1 audio
primesource hp82 chassis
Prime Source PFC SMPS 300W
budget is 80-85 as i posted before for my advise on core i7
samninc is offline
Old 27-02-2009, 08:43 PM   #2 (permalink)
RMN
Default Re: powersupply info....URGENT
you would need at least a very good 500w PSU
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 27-02-2009, 08:45 PM   #3 (permalink)
a_k_s_h_a_y's Avatar
300W for a system with HD4870. LOL !! You crazy ?? ROFLAMO !
Go with Cooler Master 600W supply. For your system, You will need it.
Yours is a high end system.
Compromising on the PSU is the biggest mistake you can make. And screw your system.
And Single HD4780 is not good enough for playing new games at FULL HD with Full High Settings, Like Crysis. You will need GTX280 or HD4870x2 !! Make no mistake. Full HD means 1920x1080.
All the best.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now
Old 27-02-2009, 08:48 PM   #4 (permalink)
RMN
its a good config but i would suggest you get a better chassis too...
at least Coolermaster Elite330 @ 1.9K
wait..
your budget is 85k..your posted config comes around 60k!
there is no reason you should settle on Primesource products!!!
with 20-25 K you can get an excellent PSU and Cabinet!
RMN is offline
Old 27-02-2009, 08:58 PM   #5 (permalink)
Crazy. It would blow up the day you bring your PC home!!!
Either get Cooler Master RS-550 Real Power 550W (5K) or Corsair VX450W (3.5K).
Warning: Do not go for Cooler Master Extreme Power Series!!! They are ticking Time-Bombs!!!
hell_storm2006 is offline
Old 27-02-2009, 09:17 PM   #6 (permalink)
oopss,,,, i forgot to add motherboard
config:
i7 920==========15.5k
intel dx58so motherb=16.5k
ati hd 4870 1gb=====17k
1tb hdd==========5.5k
benq e2200hd======12k
4gb ddr3 1333mhz ram=10k
chassis+ps of primesource=6-5k
@a_k_s_h_a_y ,, dont consufe yaar,, isnt hd4870 a best card on single gpu also considering its price...
samninc is offline
Old 27-02-2009, 09:19 PM   #7 (permalink)
The Sorcerer's Avatar
As a curiosity, mind giving a cpu-z link of your config? Need to check couple of things...
Hardware BBQ
The Sorcerer is online now
Old 27-02-2009, 09:26 PM   #8 (permalink)
havent bought yet
samninc is offline
Old 27-02-2009, 09:27 PM   #9 (permalink)
RMN
i don't think he has bought the system yet...
why primesource????!!
RMN is offline
Old 27-02-2009, 11:22 PM   #10 (permalink)
Its a good card, v.good in fact. am not saying its not nice.. its great VFM.
Even HD4870X2 will get killed by Crysis at HD resolutions and Very High Settings.
http://www.gamespot.com/pc/action/cr...982&pid=931665
Here you go, one more
http://www.tomshardware.com/reviews/...0,1953-18.html
So its like Its ok with HD4870, AVG FPS will be less then 30. For games like Crysis, if you play HD and full high settings with Anti Alising Turned on.
Old 27-02-2009, 11:40 PM   #11 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Ok, so here is sum serious stuff.
First of all, to the Original Poster, dude, with tat huge config in mind and in reality, PLZ go for atleast 750W of PSU...
Check it here if u wat to... ---> http://extreme.outervision.com/psucalculatorlite.jsp
See my siggy, and see the PSU tat i hv got (coz i will be adding 2 more gtx280, in total 3 x gtx280's in three way SLi)...
U better go for ATLEAST Corsair TX750, or if u hv upgradation in mind, like suppose u wanan add one more 4870 (to make it Crossfire)..go with atleast 1000 or 1100W psu from Tagan.....
Both Corsair and Tagan are best of brands..
Corsair 750W PSU (model TX750) ---------------> Rs. 7K
Tagan 1100W PSU (model: BZ1100) -------------> Rs. 14.1K
Cheers n e-peace...
Using tat paltry low brand PSU of 300-350W will jus NOT run ur CPU AT ALL... buddy...
So, here is the clarification:
1.) Jus one 4870 (and NOT planning to upgrade even in future) -------> 750W PSU (corsair)
2.) Planning to add more than one 4870 and also for futureproofing ---> 1100W PSU (tagan)
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Last edited by ashu888ashu888; 27-02-2009 at 11:43 PM. Reason: Automerged Doublepost
ashu888ashu888 is offline
Old 28-02-2009, 01:14 AM   #12 (permalink)
havent bought yet
That explains...
Anyways:
http://thinkdigit.com/forum/showthread.php?t=104472
Just as an FYI, 1333mhz rams are pretty disappointing against d9 micron/elpida/powerchip IC based cl4 1.8~1.9v rams if you compare the price. Check the TDP for i7 processors as well. If you are planning to buy this seriously, make sure you get some charcoal and some chilled beer for some barbeque as well. No pun intended but one has to be realistic. If you are planning to use 1TB as a primary HD for the OS as well, you are better off keeping a smaller capacity hard drive for the OS alone. As for the psu- as said before- cant afford a decent psu, dont even bother getting a decent system. More advance the system, more sensitive it is to voltage ripples and spikes. What is the purpose for this rig? Gaming? I rather save money by going for e8400+ biostar i45+ 4GB cl4 g skills rams, corsair tx650+ cm 690+ asus dx+ altec lansing mx5021+ WD 250GB primary drive and 640AACS secondary drive. Even an e7200 does well even on stock. If your reply is going to be based on the generic "future proof", then I suggest you wait for 2-3 months time. Atleast you will get better processors with lower TDP and rams will become cheaper.
Hardware BBQ
Old 28-02-2009, 12:30 PM   #13 (permalink)
You would do well Listening to The Sorcerer dude. These guys are pro like gamers. And own high end stuff.
Old 28-02-2009, 02:02 PM   #14 (permalink)
Point Blanc
/nd as per my say the specs can be future proof only on basis of your usage, you can never be future proof if intend to high resource consuming apps and games.
if buying high end stuff u need to consider cooling options, PSU and cabinet
acewin is offline
ATX powersupply Ranjya Hardware Q&A 1 02-05-2008 08:59 PM
Need info about Logitech 2.1 speakers (It's urgent) ssdivisiongermany1933 Audio 3 07-03-2007 05:09 PM
best powersupply or UPS anarchy0x Hardware Q&A 33 02-03-2007 03:24 AM
Powersupply calculator. sam9s Hardware Q&A 2 24-02-2007 11:40 AM
need info abt this.....urgent!! legolas QnA (read only) 6 24-07-2005 08:48 PM
