Old 27-02-2009, 03:44 PM   #1 (permalink)
Default Need replacement cost for dvd writer ... lenovo laptop
Hey
Does anyone know the cost for an original replacement dvd writer for a lenovo laptop ?
Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour, and it seems like a minute.
That\'s relativity - Albert Einstein
great_manish is offline
Old 27-02-2009, 05:27 PM   #2 (permalink)
Default Re: Need replacement cost for dvd writer ... lenovo laptop
its over 7K ....if you ask me then its not worth getting it replaced .......buy a LG external DVD writer drive (round 4.2k).......its pretty compact and runs directly from the USB (no power cable) ...My friend recently got one...
BTW there is no guarantee that the replacement lenovo drive will not conk out in the next few months....(my friend had to get it changed twice and it still does not work)
izzikio_rage is offline
Old 27-02-2009, 05:50 PM   #3 (permalink)
Point Blanc
for replacement cost you should contact their service center(if under warranty), otherwise search in local market. Cost in local market will be three-fourth to half and you also save labour cost.. it should come around 3.5-4 or 5K for just the burner, I think it should come to 3.5K only, but anyhow it is not 7K. and external burner from LG costs around 3.5-3.8K the slim ones and same from sony they cost 4.5K
What is the problem with your burner. check which device driver for the model.
If your part is not inwarranty take it out yourself (check in the bottomside of laptop there will be a screw for burner unscrew it and take the burner out. and get a similar burner for yourself. most of the burners supplied in laptops are LG burners.
@izzikio_rage, there is something called warranty, the service center will replace it as many times if it defective.
acewin is offline
Old 28-02-2009, 02:07 PM   #4 (permalink)
just found out from the service center .... replacement dvd write 7.5k ..... warranty extension 8.5k (dvd writer wud be replaced) ! expensive !!
Old 01-03-2009, 11:25 AM   #5 (permalink)
As I said ...go for the external drive....makes a lot of sense....The lenovo writers have a nasty habit of conking out time and again....
Old 02-03-2009, 12:14 PM   #6 (permalink)
Point Blanc
check in local market for burner for laptop.
acewin is offline
No Sound on Lenovo Laptop shivg33k Software Q&A 2 18-05-2008 10:08 AM
Suggestion for desktop replacement Laptop sakthirajesh Hardware Q&A 6 31-10-2007 09:32 PM
Not able to create HDD partition in Lenovo laptop Sharad kharya Software Q&A 3 03-04-2007 09:38 PM
Buying a Laptop - Lenovo Thinkpad arijitraja Laptops and Netbooks 3 11-01-2006 01:17 AM
