Old 26-02-2009, 11:40 PM   #1 (permalink)
I'll xploit ur Territory
niraj trehan's Avatar
Talking Cabinet...
hello i am looking for a gud looking cabinet vid gud cooling options of 3 fans under budget of 2000rs,,,,..\
can u plz tell me model n plz post pic of the cabinet u r suggesting plz....8)
P.S.
My graphic card got popped updue to overheating in my cabbie,
(c my config in my signature)....So plz Suggest me a gud 1 ...i
can extend budget upto 3000
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
niraj trehan is offline
Old 26-02-2009, 11:56 PM   #2 (permalink)
himadri_sm's Avatar
Default Re: Cabinet...
well you can try zebronics antibiotic cabinet..it is fairly spacious & without a psu will come under rs2000/-..it has a transparent acrylic panel on one side.Its got 3 fans- one at the transparent side- which glows green..one at the back & one at the top..the fan at the top can be set to rotate when the temp. exceeds a certain set point.check this link for an image- http://zebronics.net/gamingcabin.asp
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline
Old 27-02-2009, 12:18 AM   #3 (permalink)
GaMeR
@sekhar: those are good. but is there any other funkier looking cabinets in the market? with the same features and below 2k?
shadez is offline
Old 27-02-2009, 12:35 AM   #4 (permalink)
The Sorcerer's Avatar
Originally Posted by niraj trehan View Post
My graphic card got popped updue to overheating in my cabbie.
Damn. I only end up seeing some pretty weird issues here. Its NOT supposed to happen. Go for zebby cases.
Hardware BBQ
The Sorcerer is online now
Old 27-02-2009, 01:23 AM   #5 (permalink)
what about i ball???\
i am from punjab.....will i get it from delhi???
Old 27-02-2009, 02:00 AM   #6 (permalink)
what about i ball?
I was under the impression you wanted the best one for the money...
You will get this case easily in Delhi. I think cm centrurion 33x without psu comes in the same price range as well so that is also good thing to keep an eye on.
Hardware BBQ
Old 28-02-2009, 09:11 AM   #7 (permalink)
so iball is not gud??
Old 28-02-2009, 04:28 PM   #8 (permalink)
RMN
how abt Coolermaster Elite 330 for 1.9k?
http://www.coolermaster.com/products...e=2254&id=3989
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 28-02-2009, 05:23 PM   #9 (permalink)
actually i want a cabinet vid g8 luks,(i prefer vid Black colour and Flames sort of thing...lolz)
and G8 cooling options.....like that of this onehttp://www.coolermaster.com/products...e=2254&id=5269
Old 28-02-2009, 06:02 PM   #10 (permalink)
himadri_sm's Avatar
that will cost you around 4000 or more.
Old 28-02-2009, 06:18 PM   #11 (permalink)
i mean around 3000rs but that big n that gud cooling ..
Old 28-02-2009, 06:25 PM   #12 (permalink)
himadri_sm's Avatar
you can try the zebronics pro series...details on the website. i am not sure about the availability or prices though.
Old 28-02-2009, 06:35 PM   #13 (permalink)
i really like this one...
http://zebronics.net/pro_blackjack.asp
can ny1 tell me its price??
Old 28-02-2009, 06:46 PM   #14 (permalink)
himadri_sm's Avatar
why don't you check at lynx-india.com or the itwares.com? you will geta fair idea of the price.sorry i do not know the price of the Blackjack model.
Old 28-02-2009, 06:50 PM   #15 (permalink)
both sites dint provide me vid chassis prices bro!
Old 28-02-2009, 07:19 PM   #16 (permalink)
himadri_sm's Avatar
look at these links.they are not for blackjack(i couldn't find any) but you might like some other models-
NZXT
- http://www.lynx-india.com/index.php?categoryID=429
look at the alpha
CoolerMaster- http://www.lynx-india.com/index.php?categoryID=150
look at elite 334
Antec- http://www.lynx-india.com/index.php?categoryID=256
look at antec 300
Zebronics Bijli- http://www.lynx-india.com/index.php?...=810&offset=24
Zebronics Rage- http://www.lynx-india.com/index.php?...=810&offset=32
you can also check the iball workhorse model.
check it here-http://www.lynx-india.com/index.php?productID=3075
its rs6500/-
Old 03-03-2009, 10:46 AM   #17 (permalink)
going for nvidea cm690 thx guys...is it gud as compared to above..???
can u tell me what is meaning of "expansion slots"
Old 04-03-2009, 03:11 PM   #18 (permalink)
mayanksharma's Avatar
CM690 is a gr8 choice in comparison to mentioned.
Slots which allow PCI-E, PCI or AGP cards to take one extra slot during installation are known as Expansion Slots. Now, that doesn't mean that they are solely for spare. Typically, they are PCI slots and can be used for plugging in PCI cards.
mayanksharma is offline
Old 04-03-2009, 05:45 PM   #19 (permalink)
so whats the cost at vich i can get this cabinet NVIDEA CM690
Old 05-03-2009, 12:31 AM   #20 (permalink)
The Master Chief
Ronnie11's Avatar
i think its somewhere around 3400 bucks or so...
Ronnie11 is offline
Old 05-03-2009, 12:54 AM   #21 (permalink)
Nvidia edition of cm 690 is way expensive then the standard ones. Honestly, I dont find any reason to choose nvidia edition of cm690 against standard edition.
Hardware BBQ
Old 05-03-2009, 02:30 AM   #22 (permalink)
Hell is Ma PlayGround
Recently bought the Zebronics Antibiotic cabinet.
Cost me 1900 buks without smps. It has got 3 fans with sensor to monitor the temp of the CPU and RAM. Never lets the temperature cross 39c(Actually tuned the max temp as 39 ). Got myself a CM 600W smps along with it.
Check it out here http://www.zebronics.net/gamingcabin.asp
cheers,
Anup
vampiredevil is offline
Old 05-03-2009, 09:25 AM   #23 (permalink)
himadri_sm's Avatar
nvidia edition of cm690- http://www.lynx-india.com/index.php?productID=3075
its rs6500/-
Old 05-03-2009, 03:13 PM   #24 (permalink)
Whoops .....6500!!!!!
need to change my mind then....
Antibiotic doesnt appeal much2me luks wise....Bijli is Gud...
but i want to go for Sli models now..
Old 05-03-2009, 03:18 PM   #25 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Cooler Master Elite 330???
Antec NSK4400
three fans
2k
desiibond is offline
Old 05-03-2009, 03:32 PM   #26 (permalink)
Hey Centurian 590cooler master luks g8 piece....What is price?
Antec NSK4400
three fans
2k
I dont like 330 ...can u gimme link to antec!
and i was talking about this model of Cooler MASter CM 690
(RC-690)
http://www.coolermaster.com/products...e=2254&id=4149
Last edited by niraj trehan; 05-03-2009 at 03:40 PM. Reason: Automerged Doublepost
Old 20-03-2009, 01:21 PM   #27 (permalink)
got cm 690 thx guys
Cabinet LED dim mah_916 Hardware Q&A 2 20-10-2008 07:09 PM
Need Cabinet+PSU 4K Revolution Hardware Q&A 2 16-03-2008 09:29 AM
Cabinet for my rig crs_cwiz Hardware Q&A 15 06-03-2007 08:41 AM
GFX,DVD,cabinet and PSU : Help me plz... Monster_AMD QnA (read only) 5 10-06-2005 11:56 AM
