Old 26-02-2009, 09:45 PM   #1 (permalink)
Smile Desktop upgrade furrry
HI,
Presently i have P4 2.4 Ghz + 845 GVSR + 256 MB RAM + 80 GB IDE HDD.
I am planning to upgrade to C2D could you please advice. My budget is 10,000 + amount earned through selling above components.
thanks
chandan
chandan is offline
Old 26-02-2009, 09:53 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Desktop upgrade furrry
I won't be optimistic.
X2 7750 @ 3.5k
Biostar 780G @ 3.2k
2*1GB Corsair XMS 800MHz RAM @ 1.5k
Same HDD, minimum u'll have to shell out 8.2k, you have 5k.
P4 + 845 + 256MB DDR = Rs. 1500 - Rs. 2000(super optimistic) max.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 27-02-2009, 06:01 PM   #3 (permalink)
Point Blanc
better buy single stick 2GB RAM as to get benefit of max RAM upgrading.
this is the specs of mobo com is talking about Biostar A780G M2+ SE
acewin is offline
Old 28-02-2009, 12:51 PM   #4 (permalink)
Hi,
Can you give me decent config for a PC under 10,000/- And is it good to get E5200 or E7000.
Thanks
chandan
chandan is offline
[Desktop Screenshots] The Official April 2006 Desktop Thread Nemesis Chit-Chat 53 11-08-2007 12:29 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
