Old 25-02-2009, 11:56 PM   #1 (permalink)
Unhappy Memory Matter
I have an Assembled Pc ,My Configuration is
Core 2 Duo 3.0 Ghz,945G Chipset
3GB DDR2 Ram,500 GB Hdd,Windows Vista,Windows Xp.
I Have Recently Removed And Later Inserted My Ram Modules
For Cleaning,
Later After Booting In Bios the system shows 3 gb ram.
But in task manager it only shows 1 gb of Ram!
I Have checked "System Information"(Microsoft Tool)
It shows that,
Installed Memory As 3 GB
& Total Memory As 1GB.(which should be shown as 3 gb)
What's Gone Wrong?
I Have Also Checked Every Single Module Out Of three ,
All seems to be fine But After Adding them together the Problem occurs!
gameboy_advance is offline
Old 26-02-2009, 10:45 AM   #2 (permalink)
weathered!
Default Re: Memory Matter
Does it show as 1 gb ram in both the os? Try removing 2 modules and boot up and see wat happens.then do the same thing with others.
mike ming is offline
It’s just a matter of view Faun Chit-Chat 4 07-07-2008 12:40 PM
serious matter qadirahmed Mobiles and Tablets 10 28-06-2007 06:49 AM
A Matter of Speed emailaatif786 QnA (read only) 22 09-03-2007 12:35 PM
Does Megapixels matter???? maharajadhiraj Mobiles and Tablets 8 13-06-2006 12:57 AM
Matter or Not ????? FasTrack QnA (read only) 10 30-09-2004 09:22 AM
