Old 25-02-2009, 07:46 PM   #1 (permalink)
Windows--;
dinesh_ddt's Avatar
Default Pure Gaming Rig.. Nothing Else..
I'm upgrading from p4 pc...
my budget is 20k..
i got suggestions like:
1) Phenom X3 X3 - 8650+ Tri Core-2.3GHz, 3.5M
AMD 780G MA78GM-S2H 16x, 8 Ch. S, L, HDMi4
2 GB ddr2 transcend
Local cabinet
PSU pov balck diamond 500w
palit ATI HD 4670 512mb ddr3
2)P5KPL-CM INTEL G31 16x, V, 8 Ch. S, L 8)
Core 2 Duo 2.80Ghz E7400 - (3MB L2 cache 2.80Ghz 1066MHz)
2 GB ddr2 transcend
Local cabinet
Palit 9800GT 512MB DDR3
3)C2D E5200
Gigabyte G31
4 GB RAM (2x2GB DDR2 800FSB)
Palit 9600GT sonic
Coolermaster Elite 330
Coolermaster 500W PSU
Which one can i go for ?? or can u provide me one on ur own???
i can strech my budget to 22k @ max..!!
Currently Ma Brain is in beta.. B careful B4 Messing with me...
<<boom...!!!>>
dinesh_ddt is offline
Old 25-02-2009, 08:09 PM   #2 (permalink)
a_k_s_h_a_y's Avatar
Default Re: Pure Gaming Rig.. Nothing Else..
Stick to 1st Config.
The Motherboard is amazing. You can hook it to your LCD TV in living room. And pass the sound to your home theater via Optical Out.
Change the graphics Card to 9600GT.
Put a better PSU which suits this card.
May be CM 460, it costs 2.4k !!
Or try to get VIP Silver 400W Silver
Or look out for A SMPS that gives 26A on 12V Rail.
Look out for Powersafe/VIP PSU, they should cost you around 1.5k Or around.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now
Old 25-02-2009, 08:24 PM   #3 (permalink)
Windows--;
dinesh_ddt's Avatar
will 9600GT run in AMD mobo'z????
what abt psu?? r u saying 500w is too much??
<<boom...!!!>>
Old 25-02-2009, 09:06 PM   #4 (permalink)
Its a AMD Motherboard. AMD CPUs. No restrictions on Graphics Cards.
It supports hybrid corssfire, but that's only when you use plugin a low end card.
9600GT will work great. Don't worry.
Just remove Catalyst drivers, Install nVidia Drivers.
Don't forget to Install ChipSet driver though.
Old 26-02-2009, 12:11 AM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Wait for AMD Phenom II X3 720 Black Edition to hit India.
It beats ALL the BEST Wolfdale CPUs from Intel (E8200, E8400, etc) and has an extra core and overclocks beautifully.
All reviewers are suggesting it over wolfdales.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 26-02-2009, 09:56 AM   #6 (permalink)
Windows--;
dinesh_ddt's Avatar
when will they come??
what wil be their prices??
<<boom...!!!>>
Old 26-02-2009, 10:17 AM   #7 (permalink)
The Smaller Bang
Around 8K. In a few weeks.
Old 26-02-2009, 11:35 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ AFAIK, it's price is around 170$ in USA (Rs.8.5k). right? And add to it customs etc, and it will be around 10k if I am correct.
And I already heard that with little bit of overclocking E7200 beats E8200 and this one's available for 5.5k here.
Verified newegg
Phenom X3 720 running at 2.8GHz : $145
Phenom X3 710 running at 2.6GHz: $120
There is no difference between these two except the speed (which we can change if we have the right motherboard).
So, I think X3 710 is the better option IMO.
Note: For this processor to run in full glory, you need to find mobo that supports HyperTransport™ technology up to 4000MT/s full duplex, or up to 16.0GB/s I/O Bandwidth
HyperTransport™ technology up to 4000MT/s full duplex, or up to 16.0GB/s I/O Bandwidth is the same as HyperTransport speed of 2000Mhz
I would say Gigabyte GA-MA790GP-DS4H (790GX chipset) or GA-MA78G-DS3H (780G chipset with crossfireX) or GA-MA78G-DS3H (780G chipset)
desiibond is offline
Old 26-02-2009, 12:07 PM   #9 (permalink)
The Smaller Bang
X3 720 is BLACK EDITION. Means easier to get overclocks because you can just change the multiplier and nothing else.
And yeah, its not and CANT possibly be 10K. Phenom X4 810 is already 10K and everybody will buy it instead.
Old 26-02-2009, 12:28 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ah. missed that it is Black Edition. In that case, I too vote for X3 720 (unless Intel does a drastic price cut on E8200)
Old 27-02-2009, 04:47 PM   #11 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
Is Wolfdale getting older?? 'Cause I own a E8400, I thought of buying Q8200. Should I buy this proccy or should I wait and get II X3 720?? AMD's not that good in games compared to Intel's, right? Will this proccy be good enough in Games??
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 27-02-2009, 07:03 PM   #12 (permalink)
Point Blanc
if u got loads of bucks for quick change
acewin is offline
Old 27-02-2009, 10:22 PM   #13 (permalink)
Windows--;
dinesh_ddt's Avatar
so what do u guys finally suggest me...???
<<boom...!!!>>
Old 27-02-2009, 10:34 PM   #14 (permalink)
The Smaller Bang
I suggest you keep your E8400, chuck (sell) DG31PR and get gigabyte P31 mobo for 3k or MSI P45 board for 5.5K and overclock E8400 to 3.6GHz (possible on stock). Would pwn at gaming.
Old 28-02-2009, 12:43 PM   #15 (permalink)
NVIDIAGeek's Avatar
^^Will it pawn quad-core proccy's like Q8200, Q9300 or X4 9850 or even II X4 810, huh??? Anyway, how's this MoBo: Abit IP35-E Off Limits for OCing???
CRYSIS 3 FOREVAH!
Old 28-02-2009, 01:17 PM   #16 (permalink)
The Smaller Bang
yes it pwns for games crysis and older.
don't buy ip35-e unless you get free or for around 1k after exchange.
abit company has SHUTDOWN last year december 31st due to market slodown.
besides, look at P45 if you want PCI 2.0 support.
Old 28-02-2009, 02:32 PM   #17 (permalink)
NVIDIAGeek's Avatar
Ok, But in GTA IV? What's the performance diff. b/w Quad- and Dual-core??
How's this MoBo: MSI P7N SLi Platinum???
CRYSIS 3 FOREVAH!
The Pure Pwnage Thread MetalheadGautham Gamerz 43 08-06-2009 10:13 PM
Inverter , pure sine wave ? sagargv QnA (read only) 6 08-07-2008 06:08 PM
A pure HTML Website remrow Tutorials 24 17-03-2008 02:02 PM
Pure hindi programming :P rohan Chit-Chat 8 14-03-2008 01:38 PM
