Old 24-02-2009, 11:20 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Weird problem with processor fan
Hi
I'm new in the forums, I've read some of the threads and found solutions for my problems before but this is actually my first post.
Yesterday I was using my PC normally,and all of a sudden I heard a loud song, like if something fell from my desk and then my PC shutted down. I opened it and the whole dissipator plate with the fan included hooked off from the plastic base.
The base has 4 hooks on each corner, one of these broke :S. I tried to put it on place again but, before, the plate was on pressure against the processor, but after that it doesn't make that much of a pressure. I turned on my pc, it turned on but the processor temperature sky rocketed to 85°C, I had to turn it off fearing for the processor to melt down lol.
The question is:
Does the plate have to make some pressure on the processor?
It seems like the dissipation plate doesn't work because it's not making that pressure.
Does those plastic base sell apart on shops?
That's a pic of the plastic base I have, as you can see it has a square hook or something, well one of these broke completly.
If that's the problem, Could anyone explain the reason why that happened?
reiba is offline
Old 26-02-2009, 02:09 PM   #2 (permalink)
Default Re: Weird problem with processor fan
Hi, this is my first post too.
No idea why it broke, but if one of the hooks is broken, I am sorry to say this, you may have to buy a new one. For proper cooling of the processor,there should be no air between the processor and the heat dissipator plate; since there is one broken hook, some air is pushing in,causing a film of insulator. That is why the temp. of processor is rising like hell
KillerGamer is offline
Old 26-02-2009, 02:16 PM   #3 (permalink)
Intel OCer
amitash's Avatar
Yup you need alot of preasure on the processor... Buy a new cooler or find a new brarcket for this one.
My site: collegeclassroom.org
amitash is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/109384-weird-problem-processor-fan.html
Thread XPS8100 processor fan problem | Dell Community Forum | BoardReader This thread Refback 21-06-2010 11:57 PM
REALLY weird problem !!! earthen61 Software Q&A 9 03-07-2009 01:00 AM
weird xp problem chesss Software Q&A 3 30-06-2007 05:04 PM
weird problem krisjr QnA (read only) 6 23-12-2005 06:52 PM
Weird Lan Problem zodiac_511 Networking 3 25-09-2005 08:27 PM
a weird problem.... hearthacker QnA (read only) 11 03-06-2005 08:04 PM
