I have a system with following config :
1. intel G965RY
2. intel C2d e4400(2 GHZ)
3. 2GB DDR2 RAM
4. LG DVD writer.
5. Seagate 500GB HDD
6. Nvidia 8600GT graphics card
the problem is that when i switch on the system It gives 3 beep sound and nothing happens. I checked it on net and found out that the 3 beeps indicate Memory Problem. So i changed the RAM modules but to no avail. But sometimes when i take out all the components and re-assemble it, the system runs and after that again if i start the system the same problem comes. What may be the problem... Please help.
