24-02-2009, 05:16 PM
Ankit
mobo for AMD 940 processor
hi frnd's m a bit confused wich mobo should i go for with
AMD ATHLON X4 940
I CAN GO UPTO A 15,000 MOBO
24-02-2009, 05:32 PM
Bond, Desi Bond!
Re: mobo for AMD 940 processor
ASUS has released new mobos supporting DDR3 memory and lot of features.
ASUS M4A78-PRO : should be around 8k
ASUS M4A78T-E: Should be around 10k
25-02-2009, 01:34 PM
Ankit
ddr3 r quite costly corsair 3gb ddr3 ram is costin abt 7500rs
should i go for ddr3 or ddr2 ram..??
is ddr3 prices supposed to go down...?????
25-02-2009, 01:41 PM
Bond, Desi Bond!
I would say go for DDR2
My option would be Intel Core2Quad+DDR2+P45 chipset+HD4850
25-02-2009, 01:46 PM
damnbadman666
AMD athlon ??? 940 ???
ok its phenom - the mobo is ASUS M4A78T-E would best for OCing ,, go for it
25-02-2009, 03:36 PM
Ankit
i don't wanna go for intel one i already have a
i7 920
gigabyte x58
corsair 3gb 1600mhz ram
hd 4830
i want a AMD based comp for hardcore gamin
25-02-2009, 03:48 PM
damnbadman666
ya its AMD mobo only
27-02-2009, 02:43 PM
Ankit
give me a config on AMD base CPU for Only Gaming purpose upto 40,000
27-02-2009, 03:11 PM
The Smaller Bang
AMD Phenom X3 720 Black Edition - ~8K
Biostar 790GX CorssFireX motherboard - 6K
Transcend DDR2 800MHz Value RAM - 2GB + 2GB kit - ~4K
Remaining components - do you have anything else already with you ? like keyboard,mouse,monitor,PSU,gpu, etc from old rig usable here ?
Apple iPad 2 16GB WiFi
27-02-2009, 09:18 PM
EXIT: DATA Junkyard
MSI K9v2 790FX
This costs Rs. 9000
It supports :-
DDR2 1066MHz
CrossfireX 16x + CrossfireX 16x
27-02-2009, 10:35 PM
The Smaller Bang
 Dual CF 16x ???
That makes it future proof for HD5870X2.
Wait a sec, is it SB750 southbridge ???
28-02-2009, 12:28 PM
EXIT: DATA Junkyard
^^I think so yes, bcuz 790FX and 790GX both come with SB750.
28-02-2009, 01:13 PM
The Smaller Bang
wrong.
all early (aka cheap) 790FX boards had SB600.
not every board was revised with SB750.
28-02-2009, 06:10 PM
Ankit
how abt AMD X4 940....instead of x3 720
ya i have everything else ....
Reason: Automerged Doublepost
02-03-2009, 05:20 PM
The Smaller Bang
720 is better if you want to overclock. Its cheaper, supports DDR3 so you can upgrade motherboard later, is a champion overclocker and rocks at gaming since they are all dual core optimised anyway (2 cores for gaming and 1 core for OS makes 3-core kick ass).
02-03-2009, 08:27 PM
EXIT: DATA Junkyard
^^ Hmm, yes you must be right.
Whatever you do, if you want overclocking, get a Black Edition CPU.
Non B.E. CPUs don't OC well as you cannot even increase the Voltage afaik.
