Originally Posted by madyboy
Yes.... but its not working. I didn't get the bios screen up when the vga cable is connect to the gfx card...
..thats because the the primary gfx adapter is still set to the old Integrated graphics. All u hav to do is:
* boot ur pc with the vga cable connected to the old Integrated gfx port.
* Enter the BIOS, change Primary Adapter to PCI (new gfx card). save changes and reboot.
* On rebooting u wont see any monitor output. Therefore switch off the sys ASAP.
* NOw unplug the vga cable from Integrated vga port & plug in to ur New gfx card's port
* Hopefully when u switch on ur pc ur card will start functioning ( and get detected).
I really dont know why on earth would anybody buy that card. I also hav that card and it totally sucked!
. IT is way far far Old. It is from FX series line of cards that was released way back in 2004. BTW the FX series was much hyped about but failed to live up to the expectations and lost to ATI.
