Old 23-02-2009, 11:08 AM   #1 (permalink)
Default System hanging after installing SATA hard drive(250GB)
hi all,
my system hangs every 15 mins while working. i have to restart my system every time.I have windows XP SP3 now. the same problem occurs with Windosw XP SP2 also. Can you please help me in this issue.
Thank you in advance.
My System configuration
Processor AMD Athlon64
Motherboard asus 8KVX
Hard Disk 80GB IDE +250GB SATA
RAM 512+1GB (400MHz Both)
vicky_elect is offline
Old 23-02-2009, 11:42 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: System hanging after installing SATA hard drive(250GB)
Google for HD tune and download it. Run an error scan- if it happens again then change the sata port and the sata cable. If you see red dots on the hard drive- you have bad sectors so you need to RMA you drive in this scenario.
After doing this and next time you post, mention the psu. To be on the safe side, clean the vents of the psu from dust using a dry brush or can of compressed air only. Use a different molex connector to power for hard drive as well.
Hardware BBQ
The Sorcerer is online now
Old 24-02-2009, 03:20 PM   #3 (permalink)
y2j826's Avatar
reformat your system and reload everything again, it may solve the problem
http://worldofy2j.blogspot.com
y2j826 is offline
Old 25-02-2009, 01:07 AM   #4 (permalink)
a.k.a VipER
Ecstasy's Avatar
Faulty piece, must be bad sectors. I would suggest you to replace it rather than installing some softwares and fixing it as this problem may persist in future also.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 25-02-2009, 08:17 AM   #5 (permalink)
RMN
can it be an issue with BIOS not supp. a 250gb HDD?
is your BIOS the latest ver.?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
SATA Hard Drive Problems Naren Parker Hardware Q&A 5 22-07-2008 02:35 AM
SATA Hard drive not detected ?? scamper Hardware Q&A 6 08-03-2008 07:41 AM
Looking for silent SATA hard drive parimal QnA (read only) 18 06-03-2005 01:39 AM
Installing Linux in SATA Drive... khandu Open Source 3 09-08-2004 07:18 PM
