Old 22-02-2009, 11:47 AM   #1 (permalink)
RMN
Default How to apply Thermal Compund on Q6600?
i will be applying Arctic Cooling MX2 on my Q6600.
Arctic Cooling's guide says i have to apply to the middle of the CPU(in a round shape) and DO NOT spread it.
then install the cooler and AFTER installation rotate the whole cooler.
im using the stock cooler and fan.
as far as i know the heat sink comes in contact with the CPU ONLY AFTER fixing it onto to the MB..that is after locking the pins...then how the hell am i suppose the rotate the cooler?
and in ARTIC SILVER's guide say i have to apply the paste as a thin line from left to right.
now which way is better?
tq
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 22-02-2009, 11:55 AM   #2 (permalink)
Default Re: How to apply Thermal Compund on Q6600?
Faun is online now
Old 22-02-2009, 12:11 PM   #3 (permalink)
RMN
and is it ok if i don't rotate the HS?
RMN is offline
Old 22-02-2009, 12:14 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Use thin line method,don't use dot for quadcores.
And u only need to rotate 2 or 3 degrees,if u cant, leave that step.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 22-02-2009, 12:20 PM   #5 (permalink)
RMN
thanks guys.
RMN is offline
Old 24-02-2009, 06:47 PM   #6 (permalink)
RMN
i just contacted ITWares and Rahul said that Arctic Silver 5
Arctic Cooling MX-2 isn't available!
so the options are
Sunbeam Tuniq TX2
OCZ Freeze and
Cooler Master Thermal Compound KIT
which one do you guys suggest i buy?
i wont be OCing or anything.
thank you
RMN is offline
Old 24-02-2009, 06:56 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^Sunbeam Tuniq TX2 is the best and cheapest only Rs 150/- in primeabgb.
http://www.primeabgb.com/index.php?p...mart&Itemid=53
zyberboy is offline
Old 24-02-2009, 07:14 PM   #8 (permalink)
RMN
yeah just read the reviews!
its 250 rs on itwares and Arctic Cooling MX-2 is 400!!!wonder why is it so costly !
RMN is offline
Old 24-02-2009, 09:44 PM   #9 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^ya, dont know why such price variation
Arctic Cooling MX-2 only Rs 320/- in lynx
http://www.lynx-india.com/index.php?categoryID=259
zyberboy is offline
Q6600 problem meinteil11 Hardware Q&A 2 19-12-2008 05:14 PM
q6600/e8400?? coolest111 Hardware Q&A 76 19-04-2008 12:12 PM
intel Q6600 gapchoo009 Hardware Q&A 9 12-02-2008 08:37 PM
Why we have to apply thermal paste? nithinks QnA (read only) 9 18-07-2005 02:27 AM
