Old 21-02-2009, 03:38 PM   #1 (permalink)
Default Lcd Display Problem
I am using ViewSonic LCD 19" Monitor. It was not work properly. It displays in grey colour. Plese give ur suggestions to retain colour display. Please guide me.
We tried following tips.
1. It display colours when it will connect to other CPU.
2. Plugs are connected in good manner.
3. It display LCD Menu in its original colours.
Thanks for ur response.
Last edited by srikanthy2k3; 21-02-2009 at 03:39 PM. Reason: Automerged Doublepost
srikanthy2k3 is offline
Old 21-02-2009, 05:57 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Lcd Display Problem
Did you try recalibrating the brightness, contrast and other settings manually? If its needed to be replaced than I wish you luck.
Hardware BBQ
The Sorcerer is online now
Old 21-02-2009, 08:11 PM   #3 (permalink)
moshel's Avatar
i think you will need to make come setting in your display menu in windows or if you have a nvidia graphics card then through the nvidia software.
moshel is offline
Old 22-02-2009, 04:20 AM   #4 (permalink)
Point Blanc
do a little play around in LCD Display menu and also the gfx card software.
have you checked attaching to anyother system.
acewin is offline
IE Display Problem skghosh44 QnA (read only) 13 15-02-2008 01:15 AM
Display Problem Nimtshey Hardware Q&A 12 27-10-2005 01:16 AM
Display Problem sudhirkumar001 QnA (read only) 9 05-10-2005 12:02 AM
display problem raj_amd QnA (read only) 1 15-06-2005 11:27 PM
display problem in xp geekgod Software Q&A 3 23-12-2004 01:04 AM
