Old 21-02-2009, 02:50 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Noobness unleashed....
Default Question regarding dell studio 15
I am ordering this laptop on monday. If anybody could answer some questions of mine it will be a gr8 help...
1. Is it advisable to go for 512 mb ati hd 4570 instead of 256 mb. Means will it have any performance boost?
2. Should upgrade hard drive to 7200 rpm from 5400 rpm? What type of boost this upgrade will have?
3. And finally this one is the most confusing, should i go for intel wifi link 5300 (802.11) half-mini card instead of intel wifi link 5100. I only connect to my college wifi which is 50-60 mbps lan network.
Also any colour suggestions..?
No mortal can keep a secret. If his lips are silent, he chatters with his fingertips; betrayal oozes out of him at every pore.
- Sigmund Freud
prakash.gourav is offline
Old 21-02-2009, 01:01 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Question regarding dell studio 15
1. Depends which one is ddr3 and which one is ddr2.
2. Personally, I havent seen much different between drives unless its something like a raptor or SSD drives. Stick to 5400rpm to save extra cash.
3. Laptops do have inbuilt wifi adapters. I think the one for dell is either broadcomm or intel. The speed is more depending on the ISP/router/settings. wifi adapters are just receivers. But the ones dell sends (and some older ones) do support 802.11 a/b/g/n.
I work for Dell U.S. so we give a hardware warranty and if customers want software warranty, then Dell on call tech support charges $239 which covers 4 major incidences wityh 72 hour of grace period for each issue with a validity of 1 year. I am not sure how Dell India works, but the point is get information and confirm if the warranty they are giving is only for hardware or does it cover software.
Hardware BBQ
The Sorcerer is online now
Old 21-02-2009, 02:51 PM   #3 (permalink)
what is the cost of the this laptop and where are you buying it ?
just checked the site ......it does not say weather the graphics card RAM is ddr 2 or 3 ......any suggestions on how to find out
Last edited by izzikio_rage; 21-02-2009 at 02:55 PM. Reason: Automerged Doublepost
izzikio_rage is offline
Old 21-02-2009, 03:36 PM   #4 (permalink)
weathered!
finally found some body buying studio 15!! m getting my studio 15 on tuesday!
1. go for 512 if ur a hardcore gamer or else settle for 256mb
http://www.notebookcheck.net/AMD-ATI...0.13885.0.html
2. 7200 rpm will eat up ur battery. if ur not concerned with this then go for it.
3. 5100 is more than enough for the requirements u have.
the GPU is available in GDDR3, DDR3, DDR2. check the above site for ur graphics related queries.
mike ming is offline
Old 21-02-2009, 04:11 PM   #5 (permalink)
It is 50k unconfigured without taxes and i will order it online.
Yes i like playing games a lot... So i would like to go for 512 mb vram if it offers even 10% performance gain. I dont know if it is gddr2 or gddr3. Is there any way to find out?
Does 7200 rpm hard disk gives better performance gains in games? I am not concerned about battery.
So if u people say that intel 5300 will not give any performance gains, i will go for a backlit keyboard.
- Sigmund Freud
Old 21-02-2009, 05:49 PM   #6 (permalink)
Best if you confirm via calling Dell India and ask them personally. If your city needs to pay octroi, then that will be included later. Just as an FYI- 256MB ddr3 is better than 512MB DDR2. As I said- I haven't seen any much difference between 7200RPM and 5400RPM- its more depending on how many platters are there on the hard drive and sequential read speed, ram read speed and average transfer rate. For a 50k, one can go for a desktop and this way you can enjoy better games. Other than that, its the pointers I gave you.
Hardware BBQ
Old 21-02-2009, 06:22 PM   #7 (permalink)
Cool G5's Avatar
If your sole purpose is gaming then better get a Desktop instead.
Cool G5 is offline
Old 21-02-2009, 06:35 PM   #8 (permalink)
S60 rocks
rajhot's Avatar
1. Go for 256 MB card
Proud Owner of N82! :cool:
rajhot is offline
Old 21-02-2009, 08:42 PM   #9 (permalink)
256 mb ddr 3 is cheaper than the 512 MB ddr2???? the dell site is adding 1600 bucks to upgrade from the 256 to 512.....can someone please check if it really is a ddr3 card....
Old 22-02-2009, 01:15 AM   #10 (permalink)
I will upgrade my desky later. Right Now i need to have this laptop and want to maximize the gaming performance on this configuration.
I am willing to spend 1.6k for 512 mb vram. Addition 0.5 for red colour and near 1k for backlit keyboard. That way it shall cost near 54k with taxes. But i will get an additional 5% discount for being an iit student. Henceforth it will cost 52k. Is it allright guys?
I am not going for 7200rpm hdd and intel wifi 5300 as u guys suggested...
- Sigmund Freud
Old 22-02-2009, 05:29 AM   #11 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Originally Posted by The Sorcerer View Post
1.
dude which site ?
cuz Im also In Dell USCTS ...
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 22-02-2009, 08:26 AM   #12 (permalink)
^^ Dell on call tech.
Hardware BBQ
Old 22-02-2009, 01:00 PM   #13 (permalink)
By the way, i also play a lot of games on wifi. Usually there is lag. Will intel 5300 give greater performance?
- Sigmund Freud
Old 23-02-2009, 07:14 AM   #14 (permalink)
Its more on the router and the connection when it comes to lag. However, many gamers still prefer the good old fashioned but more reliable rj45 cable over wifi for gaming. As for onboard wif you just need to make sure it works on 802.11b/g/n which all new ones will.
Hardware BBQ
Old 23-02-2009, 11:08 AM   #15 (permalink)
weathered!
Go for the xps gaming laptop.
http://www1.ap.dell.com/content/prod...hs1&l=en&s=dhs
Old 23-02-2009, 02:24 PM   #16 (permalink)
how do you get a discount for being an IIT student? and what other colleges are there in that list ....? any chance of ISM dhanbad being there?
BTW is the graphics ram ddr 2 or ddr3 ?
Old 23-02-2009, 05:28 PM   #17 (permalink)
Red till Death..
abhisheksohal's Avatar
Yea...plz let us know how to get that student discount..coz im in PEC,chandigarh..and i also wanna know that is this laptop available in retail stores like some other models of dell are available??
abhisheksohal is offline
Old 25-02-2009, 02:34 PM   #18 (permalink)
@prakash.gaurav ...dude ....how do we get that student discount???????
Old 25-02-2009, 02:52 PM   #19 (permalink)
@ thread starter
faster harddrive will only reduce the loading time etc. , their will be no performance gain in games..
regarding gfx card, configure the system and submit, when they call you and send the final quotation, most probably they will mention if it is ddr2 or ddr3, or ask them before payment.. also any wifi card will be sufficient for ur requirement..
foruamit2004 is offline
Old 25-02-2009, 03:50 PM   #20 (permalink)
even the final statement does not tell whether the card is ddr2 or ddr 3 ....and the ATI 4570 is so new that there are no reviews available for it..
Old 26-02-2009, 10:28 AM   #21 (permalink)
Sorry guys for replying late. I am waiting for the draft to be sent to dell.
The quotation doesn't say whether gfx card is ddr2 or ddr3... I think it must be ddr2 otherwise they would have surely highlighted the feature on the site.
And about discount-
when i asked about it, the call centre guy confirmed it and said that i will have to send the quotation to him so that he can verify me. However, in end he just sent the final quotation to me instead with all the discount. So i think, the extra discount is availaible if you upgrade the configuration a little bit.
Just ask them and ask.
Otherwise i can send the quotation for you using my iit id. No problem.
Thanks for all the help guys.
- Sigmund Freud
Old 26-02-2009, 12:17 PM   #22 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
HD4570 can't really use 512MB of RAM and give a huge performance boost.
See the second (48K) config in Dell website of Studio 15.
In that, change HDD to 7200RPM and upgrade to 9Cell battery.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 26-02-2009, 06:20 PM   #23 (permalink)
Red till Death..
I wanna ask ..is this laptop available at the Dell retail stores, (With the Ati radeon 4570)??? And one more thing..im plannin to buy Zenith director plus ultra...if i buy that then i'll have a P8400 2.26 ghz ,3mb cache,1066Mhz Fsb processor with Geforce 9600M GS(512 mb ddr2) nd 4gb ram ..and if i go for dell studio 15 then I will only be able to afford T6400 2ghz ,2mb cache,800Mhz fsb processor and Ati radeon 4570 and 3gb ram...so i wanna know that which will have better gaming performance?? Coz in the comparisons on the notebookcheck.net site...P8400 processor is ranked at 34 while T6400 is ranked at 58..and the Ati radeon is shown to be better than 9600M GS...so which laptop will run games better???
Old 27-02-2009, 09:36 AM   #24 (permalink)
I got some feedbacks about the zenith service....its not too good....for home users having desktops they take forever to come and repair things ...same for corporate customers...plus the quality of their stuff is nowhere near that of MNCs ...so long term reliability is a big question ....I checked with friends in Jaipur , ujjain , and Delhi....
All in all I guess the extra money that dell is asking is worth it considering that there are no other options in this range ....specially with good graphics solutions...
Old 27-02-2009, 10:22 AM   #25 (permalink)
The Smaller Bang
Zenith.
9600M GS is better than HD4570. Remember that 9600M GS is the lower end mid-range model from nVidia while HD4570 is the highest RV710 (low end) GPU from ATI.
And yeah, since the resolution of Studio 15 is higher than Director Ultra Plus, it will have lesser frame rate.
Old 27-02-2009, 12:37 PM   #26 (permalink)
Red till Death..
I got a call from the dell support today in response to my mail that i had sent them. They told me that it;ll cost me 46k final for the dell studio 15..wid T6400 2 ghz processor,ati radeon 4570,3gb ram etc. It'll be totally out of my budget even then...so im goin for zenith only...besides i personally feel tha nvidia cards are better in performance and also the regular driver support..
Old 27-02-2009, 02:19 PM   #27 (permalink)
The Smaller Bang
Good.
Lol, the brand does not determine the performance.
You should look at the model number, core clock, vram, shader count, vram clock, power consumption, etc instead.
And no, drivers from AMD are not that bad. They just have longer release cycles, but that doesn't affect performance.
Having said that, 9600GS is ANYDAY better than HD4570
Old 27-02-2009, 02:38 PM   #28 (permalink)
hey there are no benchmarks for the 4570 yet....and the sites have tentatively rated it as better than the 9600 ......Its still anyones game... ...
Old 27-02-2009, 02:53 PM   #29 (permalink)
@ abhi, if i were yuo and havn't seen the new dell then i wud have bought the zenith one, but after seeing the new dell studio, i wud rather wait for some days untill some benchmarks are out for ati 4570...but for 10k difference wud always prefer dell, offcourse with backlit keyboard, also 15.6" 16:9 led screen is really good for movies/tv shows..
Old 28-02-2009, 03:13 PM   #30 (permalink)
Red till Death..
I saw this video on youtube..where this guy has an Asus F6Ve-B1 laptop with HD4570 512 mb ddr2 ,C2D T9550(2.66ghz) ,4gb ddr2 ram! And hes shown the benchmarks on 3dmark 06 ...its just 3521 on 1024x768!! while geforce 9600M gs easily goes above 4000 on 1024x768 on 3dmark 06 and even more depending on the processor..like its 4622 at 1024x768 withT9400(2.53 ghz) processor !!
Heres the video..
http://www.youtube.com/watch?v=W9MMpraU71g
So its zenith for me no questions asked!
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/109085-question-regarding-dell-studio-15-a.html
Thread Question regarding This thread Refback 20-10-2010 06:10 PM
Dell Studio 15 Review mukul Reviews 18 24-04-2009 12:27 AM
Dell 430 Desktop Or Dell Studio XPS 16 Lappy nimbus_007 Software Q&A 2 23-02-2009 02:13 PM
Dell Studio XPS 13 & 16 Laptops aytus Reviews 13 21-01-2009 10:58 AM
DELL XPS or Inspiron or Studio s18000rpm Hardware Q&A 16 15-10-2008 09:44 PM
DELL Studio Or XPS ? naveen_reloaded Mobiles and Tablets 23 14-07-2008 01:32 AM
