Old 20-02-2009, 11:31 AM   #1 (permalink)
Default crc check error While copying data within hard drive
What may be the problem if crc Check error occurs when copying data within the disk from one drive to .another . i had changed the hard drive to new after four months the problem now started with the new drive what may be the problem .
prakashr85 is offline
Old 20-02-2009, 12:44 PM   #2 (permalink)
Point Blanc
Default Re: crc check error While copying data within hard drive
CRC check dows not mean bad HDD, but bad data. some portion of data may have gone bad due to which CRC checksum is not getting correct, can happen if the data keeps sitting for long time. Happens alot many times in optical disc as the sectors start becoming bad and unreadable. But can happen in HDD if the part of the HDD on which the file is, gets overwrite due to any reason, which can be due to bad/ incomplete copy, etc etc.
finally it can happen if any bad secor develops in the HDD, so have checked your HDD, run "chkdsk /F" on windows. In case of Bad sector it wont be a CRC error but those sector will become unreadable and windows will warn when you will try to do so.
acewin is offline
copying Hard Drive To DVDs? Plz Help RajivKumar123456 QnA (read only) 14 17-12-2008 06:57 PM
I/O error while copying some data on to external HDD gary4gar Open Source 4 02-11-2007 12:31 PM
Data recovery help needed for flashtrax portable hard drive kevin_476 Hardware Q&A 1 18-01-2007 12:16 PM
hard drive data transfer question :D Angeldust33 QnA (read only) 14 01-10-2005 01:45 PM
Hard drive data recovery pathakjr1 QnA (read only) 4 06-11-2004 11:04 AM
