Old 19-02-2009, 02:32 PM   #1 (permalink)
Post Need PC worth 35-40K
Hi,
I am gonna buy new pc with following components only,
Proc & motherboard,PSU,cabinet,RAM,GPU,DVD writer & HDD
I am not thinking of buying new sys for 2-3 year
only can upgrade RAM,GPU later.
Uses: Gaming(overclocking), Animation and entertainment.
I hv sorted this:
1.Intel Core 2 Q8200
2.MSI P45 Platinum Motherboard/MSI P45 Neo2-FR
3.Corsair VX 450 Watts
4.Coolermaster CM 690
5.Kingston 2GB DDR2 800/1066MHZ (ll upgrade it to 8GB within next 2 months)
6.Palit HD 4850/4870 (512MB)
7.WD 500GB
8.Sony DVD WR
How is this config?
if not good Suggest me nice one,please.
nikhil_mandlik is offline
Old 19-02-2009, 07:53 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Need PC worth 35-40K
change to:
1.amd ohenom 2 940--12k
2.biostar 790gx--5k
3.keep same psu
4.keep the cabby
5.make it transcend 4gb ddr2 800--2.5k
6.MSI HD4870--12k
7.keep same HDD
8.Try samsung sata dvd writer at 2k.
My site: collegeclassroom.org
amitash is offline
Old 19-02-2009, 08:46 PM   #3 (permalink)
Point Blanc
SAMSUNG SATA burner would not cost 2K , its less than 1.1K
buy a SATA burner, wil save up space inside the cabinet. and samsung one is good.
you can get SATA burner in sony also.
in 12K it is Pehnom 2 920 not 940 I think
acewin is offline
Old 19-02-2009, 08:56 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Originally Posted by amitash View Post
change to:
2.biostar 790gx--5k
3.keep same psu
4.keep the cabby
6.MSI HD4870--12k
7.keep same HDD
DVD Writer @ 1.1k
MSI HD4870 512MB GDDR5 @ 12.8k
Get Phenom II 920 @ 10.5k instead.
The max u'll be OCing is 3.6GHz i guess, and this one goes 3.8GHz anyways.
Get Corsair VX550W @ 5k becuz of HD4870 and a P2 processor, both power hungry.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 19-02-2009, 10:34 PM   #5 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
Maybe a CoolerMaster 600W for Rs. 5.8k
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 19-02-2009, 10:37 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
or a Tagan BZ600 600W modualr PSU @ Rs. 6K
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-02-2009, 10:38 PM   #7 (permalink)
damnbadman666
damngoodman999's Avatar
^^^ its 3.6K for coolermaster 600 watts
AMD phenom2 +HD 4870 +4GB RAM ====== woah wonderfull !! nice gaming rig out there
Last edited by damngoodman999; 19-02-2009 at 10:39 PM. Reason: Automerged Doublepost
damngoodman999 is offline
Old 20-02-2009, 08:46 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get the CM600W for HD4870, cost as given above^^
About me:
Old 21-02-2009, 08:36 AM   #9 (permalink)
RMN
based on what ive read recently don't go for CM600W.
can CM600W handle a 4870 and Q8200 anyway?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 21-02-2009, 12:36 PM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^yes
About me:
Old 05-03-2009, 03:55 PM   #11 (permalink)
Hi
I was planning to buy AMD but scraped it because of heating issues and AMD is new into 45nm and also Q9400 processor is good competitorto phenom 940 in gaming and rendering(better than 940)...........................correct me if I am wrong
So i have decided to go with new extended budget...........
Intel Q9400............................................. .................12000
Gigabyte EP45-UD3P.............................................. ......9000(doubt)
Corsair VX 550 Watts............................................. ......3500
Coolermaster CM 690............................................... ....3900
Kingston/Transcend 2x2GB DDR2 800MHZ.........................2000
Palit HD 4850 (512MB)........................................... .......7500
WD 500GB............................................. .....................2850
Sony DVD WR................................................ .............1100
Total around: 42000/-
Suggest me nice Motherboard around 7K..................doubt abt price of this one
Old 05-03-2009, 04:02 PM   #12 (permalink)
Bond, Desi Bond!
desiibond's Avatar
If your display is 22" or more, Make a little bit of changes.
Phenom 920(10k) + Gigabyte 780G based board(5k) + HD4870(13k-15k) will be lot lot lot lot more faster than Q9400 + Gigabyte EP45-UD3P + HD4850.
My home PC having Athlon 64 2.2GHz (single core) + ATI 2600XT is lot faster (in video rendering and gaming) than my office PC having Intel Core2Duo E6300 + Quadro NVS 540. 2600XT made a huge difference in performance.
desiibond is offline
Old 05-03-2009, 04:09 PM   #13 (permalink)
currently I hv 15" monitor.............1024X674
But gonna upgrade later to 19" Samsung
Old 05-03-2009, 04:12 PM   #14 (permalink)
Intel OCer
amitash's Avatar
the phenom 2 940 is better than Q9400 in both gaming an rendering...Only the Q9550 competes with p2 90...So get this:
1.phenom 2 940 ---------------- 12k
2.A 790gx mobo like biostar------ 5k
3.cooler master 600W------------3.6k
4.MSI HD4870--------------------12.5k
5.CM690-------------------------4k
6.transcend 4gb ddr2800---------2.5k
7.WD500gb----------------------2.8k
8.samsung sata dvd writer--------1.1k
TOTAL: 43k
The 4870 PWNS the 4850...With the AMD option you can get the 4870.
amitash is offline
Old 05-03-2009, 04:16 PM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
with that setup, FullHD display will make more sense. quadcore+hd4870 on a 19" is not a good setup ( unless you do 90% video rendering and 10% gaming )
Check BenQ 22" display. It costs around 10k I think.
Old 05-03-2009, 04:21 PM   #16 (permalink)
sumitdut's Avatar
Go for BenQ its rokxx
XFX 750i SLI ready(nvidia)/Core 2 quad q8200/8 GB DDR2/XFX nvidia GTX 285/500 GB Seagate/19" BenQ/CoolerMaster realpower 700w moduler PSU/Windows Vista 64Bt
iPhone 3G/Playstaytion2/XBOX 360
sumitdut is offline
Old 05-03-2009, 04:53 PM   #17 (permalink)
I m gonna buy LCD later.....................may b after 3months
So till then............................15" will work..................
...........i was thinking of ............HD4850 bcoz ..............later after 1-1.5 year I gonna get nice dX11 supported GPU........
So now whats ur commnets?
need suggestion.
Old 05-03-2009, 05:19 PM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
as I said earlier, you get more performance out of X4 940+HD4870 than from Q9400+HD4870.
YOu are not losing anything. both setups cost the same price, then why not go for HD4870.
Forget about future, Get the best you can get now.
DX11? Name 10 dx10 games? Name one dx10.1 game
Old 05-03-2009, 05:31 PM   #19 (permalink)
So what about the heating problems with AMD phenom II?
And is this board with AM3?
bcoz q9400 + gA EP45 UD3P--------- no scope for future upgrade
But if I go with this I think there ll be upgrade option in future right?
Old 05-03-2009, 05:47 PM   #20 (permalink)
Bond, Desi Bond!
desiibond's Avatar
nope it's am2+
yes.
Old 05-03-2009, 05:51 PM   #21 (permalink)
If this is the case then I need cooler............
Might after 2months.................Thermalright ultra 90I?
Old 05-03-2009, 05:58 PM   #22 (permalink)
Intel OCer
amitash's Avatar
^+1 for ultima 90i
farcry 2
amitash is offline
Old 05-03-2009, 06:07 PM   #23 (permalink)
^+1 for ultima 90i
Whats the current price of it?
And biostar 790gx is good for 2-3 year? (it has nice features for price)
The whole system is gonna remain same for 2-3 years........
Small upgrades ........... no issues..........
Old 05-03-2009, 06:16 PM   #24 (permalink)
Bond, Desi Bond!
desiibond's Avatar
farcry 2
is it?
OKay, then name two
Old 06-03-2009, 05:51 AM   #25 (permalink)
Fast 'N' Furious
topgear's Avatar
Yes Far Cry 2 is based on DX 10.1. Other two games :
Assassin's Creed - Earlier version supports DX 10.1. but patch v.1.02 removed DX 10.1 support ( I've the 1.0 version )
S.T.A.L.K.E.R.: Clear Sky - since Patch 1.5.06 supports DirectX 10.1
( I've patched it to v.1.5.0.7 )
topgear is offline
Old 06-03-2009, 07:14 AM   #26 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^wow. I didn't know this. this is good.
Old 06-03-2009, 09:40 AM   #27 (permalink)
Intel OCer
amitash's Avatar
lol... Still dx10.1 is pointless....@threadstarter, nothing in the world of computers is future proof for gaming.... New hardware and games keep coming out...... You can expect 1-1.5 yr with it.... The core i7 though will last a very long time as games will take atleast 2-3 more years to make use of the 8 processors
amitash is offline
is n81 worth to buy it nilesh5647 Buying Advice 4 07-02-2008 12:31 PM
and worth 15k.....!!!!!! adi87 Buying Advice 10 15-05-2006 02:37 PM
Worth 10k adi87 Buying Advice 28 15-05-2006 10:19 AM
