View Poll Results: Which graphical interface is best in Linix?
KDE 1 50.00%
Gnome 0 0%
XCFE 1 50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Old 19-02-2009, 10:09 AM   #1 (permalink)
Technology making us DUMB
Question Wierd Problem with DVD Writer
Hi Troubleshooters,
I was using LG's DVD Writer since last 1.5 years with my Seagate 40 GB IDE HDD. It was and it is working seamlessly with that HDD. Recently I've purchased a new Seagate IDE HDD @160 GB. Since I've started using this HDD, am facing a wierd problem. Althogh I am able to boot and install Windows from this DVD writer, but the moment I start using windows, it is not able to read data from the DVD drive, and even not able to write data as well, to check this, I again booted my PC with the old HDD (40 GB) and it is working smoothly w/o any glitch.
Reloading the OS didn't help either; to cross check, I installed Linux Mint on another partition of the new HDD, which also booted and installed from the same DVD drive and it is also not able to read/write the data from/to the DVD drive.
I am not willing to try to re-install the OS on the old HDD as it may leave me w/ no backup which I used to take on DVDs as a usual practice.
Please Please Please help me.....This problem is wierd as the same OS which I used to load from the same DVD drive is not reading contents from it .
coolchop is offline
Old 19-02-2009, 10:26 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Wierd Problem with DVD Writer
Windows xp certain updates on sp2/ sp3 has PIO/DMA conflicts. For sata dvd writer, change the advance settings on IDE/atapi controllers to DMA. Same might be required in BIOS.
Hardware BBQ
The Sorcerer is online now
Old 19-02-2009, 10:33 AM   #3 (permalink)
And how should I do this in Linux??
RE: Windows xp certain updates on sp2/ sp3 has PIO/DMA conflicts. For sata dvd writer, change the advance settings on IDE/atapi controllers to DMA. Same might be required in BIOS.
My rig: http://www.techenclave.com/rig-galle...llery-738.html
coolchop is offline
Old 19-02-2009, 11:52 AM   #4 (permalink)
Not sure about linux though you can try putting the dvd writer in dma mode on your mobo's BIOS. If it doesnt work out, best if you put it in the linux section most probably the advisors there know what to do.
Hardware BBQ
Wierd problem kuki_295 Software Q&A 7 01-04-2008 11:36 PM
Wierd Problem skippednote Software Q&A 3 29-02-2008 07:15 PM
Wierd Problem in XP Prabhagaran Software Q&A 12 22-09-2007 12:05 PM
a really wierd problem vikram Software Q&A 2 15-05-2006 10:49 AM
Wierd problem with my net drvarunmehta QnA (read only) 4 04-02-2005 11:23 PM
