Old 18-02-2009, 07:49 AM   #1 (permalink)
Default WiFi Router Dilemma
Soon I am changing my dataone broadband plan to unlimited so that I can connect my laptop wirelessly from anywhere in my home. Please tell me, should I buy the default type II router from BSNL or should I buy any other wifi router. Please suggest..
Thank You
http://mobiveda.com
vineetrocks2005 is offline
Old 18-02-2009, 10:34 AM   #2 (permalink)
Point Blanc
Default Re: WiFi Router Dilemma
if u have a router from BSNL, then see will the exhange to wireless router.
they charged me 1800 when i got my connection first time
acewin is offline
Old 18-02-2009, 10:38 AM   #3 (permalink)
I think they only exchange rented modems...I purchased my modem when I got the connection..so I don't think there is any chance of exchanging the modem with wifi modem...
http://mobiveda.com
Old 18-02-2009, 01:40 PM   #4 (permalink)
Point Blanc
then better of buying a good wireless router which suits you, likes of linksys and D-Link
acewin is offline
Old 18-02-2009, 02:10 PM   #5 (permalink)
S60 rocks
rajhot's Avatar
How much is the type II router?
If its more than 2k then go for linksys WRT 54 router
Proud Owner of N82! :cool:
rajhot is offline
Old 18-02-2009, 03:33 PM   #6 (permalink)
it is priced at Rs. 1600
http://mobiveda.com
Old 18-02-2009, 09:41 PM   #7 (permalink)
Point Blanc
i wud say go for separate router from linksys, and if wanna keep low cost check in the bazzar section for some good second hand.
acewin is offline
Old 19-02-2009, 09:52 AM   #8 (permalink)
is there any special model from linksys or Dlink that you would like to suggests..
http://mobiveda.com
Old 19-02-2009, 10:17 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Linksys WRT-54G2
Linksys WRT-54G
desiibond is offline
what wifi router to buy? gauravsuneja Hardware Q&A 14 13-11-2008 03:40 PM
Wifi Router? narangz Hardware Q&A 43 22-07-2008 01:42 AM
Need some help in buyin a wifi router NahSoR Networking 1 21-06-2008 09:00 PM
Need a wifi Router.... gsenthil Hardware Q&A 2 06-05-2008 03:15 PM
