Old 17-02-2009, 08:57 PM   #1 (permalink)
Default DVD drive problems
Hi,
I bought a new DVD drive, which is a Samsung SATA DVD writer drive.
I connected to my pc and I find that drive shows up correctly in the CMOS and while booting the DVD activity LED blinks.
But if I try to open the Drive with the eject button or through windows explorer ( right click -> eject ) it does not open.
If I do a double click on the drive it just shows a blank window. Is this a problem with the DVD drive. Do I need to take the drive to the service centre ?
I even tried changing the SATA data connector on the motherboard and tried changing the power cable connecting to the SMPS. But as it is getting detected in the CMOS I dont find a problem with all these and suspect an issue with the Drive. It is a new drive. Please let me know you views and inputs.
Regards
Karthigeyan
karthik_jce is offline
Old 17-02-2009, 10:43 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: DVD drive problems
Looks like it has somekind of tray issue. Send it to the service center for replacement.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Problems with my pen drive dabster Reviews 2 21-03-2009 06:50 AM
USB Pen Drive Problems mannuforall Hardware Q&A 3 20-03-2008 08:14 PM
USB pen drive problems the_player Hardware Q&A 2 02-01-2007 11:32 AM
USB Drive Problems d Hardware Q&A 1 20-12-2005 02:03 PM
