Old 16-02-2009, 07:30 PM   #1 (permalink)
Unhappy Why doesn't my hard drive let me save anymore stuff?
I have a 500GB hard drive, I've only used 90GB so far but when i try to put more stuff into something it says there is not enough space on the disk. Plz someone help me!
manoj_mafiosi is offline
Old 17-02-2009, 08:57 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Why doesn't my hard drive let me save anymore stuff?
Pretty strange think digit has much poor support despite people claiming thinkdigit is the most active forum...
Google for hd tune and run error scan. If you see any red dots, you have bad sectors. Next time you post do mention the configuration inlucluding the psu, the make of the drive and the connection it uses- sata or IDE to make things easier for you and others so we can be on the same page.
Hardware BBQ
The Sorcerer is online now
Old 17-02-2009, 10:35 AM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Why doesn't my hard drive let me save anymore stuff?
First run a chkdsk on it...
Analyze d result...and then run Defrag...
Reply ur result here...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 17-02-2009, 02:42 PM   #4 (permalink)
if this problem is copying any file to anyplace or some file to any specific drive/folder??anyway try as said above..
btw if the drive fromat is fat32 then you can not copy files > 4gb..
foruamit2004 is offline
Old 17-02-2009, 03:25 PM   #5 (permalink)
post your detail HW, SW configuration.check out jumper settings if its pata.some settings restricts drive in a fraction of full. check out BIOS also.
dips_view is offline
I Cant take it anymore azzu Open Source 13 23-05-2007 03:12 PM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
old hard drive in new pc ? Angeldust33 QnA (read only) 3 30-09-2005 05:22 PM
Hard Drive toooo hard for 815 Sonu Yadav QnA (read only) 20 16-06-2005 03:55 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
