My config is ;P4 1.7 Ghz ,845 mobo,Gainward Nvidia 6800le,512 md ram,400 Watt cheap PSU.My monitor is going blank ,LED of the monitor goes from green to orange color.Cpu is just running and sound also play for some time and then stops.Nothing works in attempt to start the pc.i have to restart the pc again.firstly it was happening in only games like while playing bioshock (when i start bioshock ,it goes to menu screen then suddenly monitor goes blank.it happens at just same moment many times.and in other games also while loading another map or any time,it wants).now it just goes blank while idle or surfing net.Computer runs fine on onboard graphic.i have changed the rails of psu ,so thet only graphic card is there on single rail.firstly it works but now it make any difference.i have searched many forums.so,please tell me,is it:-
1.Graphic card problem (read in many forum that blank screen is typical in 6800le models)
2.PSU problem as my psu is cheap quality
3.Monitor problem
4 Other problem as you suggests.
please help
